Cord For Range Oven. Help!! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2014, 07:34 PM   #1
Rewards Points: 4
cord for range oven. help!!
hi everyone
i just bought a new house, there is no outlet behind range oven, instead, there is a cord directly from wall. what bother me is that the cord looks wired. there are two black cord and many small copper wire in that cord. i don't know how to connect to my oven or to a outlet? any suggestion? thank you!
kevin10 is offline   Reply With Quote
Old 11-14-2014, 07:44 PM   #2
Rewards Points: 58
I'm guessing that all those little wires are actually your ground wire. Further into the outer jacket, those individual wires are likely twisted together to form a heavy gauge ground wire.
Eddiethekub is offline   Reply With Quote
Old 11-14-2014, 07:47 PM   #3
Licensed electrician
Rewards Points: 3,688
You need to install a 3 prong surface mount receptacle on the SE cable. The two insulated go to the X and Y terminals. The other will go to the center terminal after you spin it into one conductor.
Jump-start (11-14-2014)
Old 11-14-2014, 07:56 PM   #4
Rewards Points: 4
thanks for all responds!!
Old 11-14-2014, 08:01 PM   #5
Rewards Points: 3,146
I'm thinking a copper thief has been in that house and that mess needs to be checked out by a qualified electrician even though this is a DIY site.
Old 11-14-2014, 08:52 PM   #6
Rewards Points: 1,832
The 2 blacks are your hot wires, the bare concentric strands are twisted together to form your neutral wire. A 3 wire, NEMA 10-50 receptacle would be your choice on this one.
Jump-start is offline   Reply With Quote
Old 11-15-2014, 10:17 AM   #7
Master Electrician/Owner
Jrannis's Avatar
Rewards Points: 128
I would be very reluctant to use that cable.
If it's impossible to change, maybe you could have an electrician Meg the cable for you. It could have been pulled into a staple and smolder inside of the wall.
Best would be to have a new cable installed, 8/3 w a ground and change to a 4 wire.
Jrannis is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Replace power cord on Kenmore Canister vac? Ultrarunner2017 Appliances 7 06-14-2014 11:47 AM
oven power cord Startingover Electrical 15 06-06-2013 06:18 PM
oven cord kray333 Appliances 2 05-10-2012 07:18 AM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
