Cooper Or Leviton GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 04:08 PM   #1
Rewards Points: 278
Cooper or Leviton GFCI?
hey guys which one do you recommend? I don't really care for the light
I read some of these one draws 1W constantly? I am going to replace all regular receptacles in the kitchen with GFCI.. all 5 of them. (yes I understand downstream is protected already, but it looks more professional)
The thing I have against the cooper is that, it yellows, really, it start to look different from the switch and plate beside it, well maybe because the plate and switch were leviton parts and they don't quite age the same way.
But other than that, no difference which brand I go with right?
DIYGST is offline   Reply With Quote
Old 06-22-2009, 06:36 PM   #2
Why not replace the other outlets with the rectangular decorator outlets @ $2.50 each instead. They look like GFCI outlets without the test and reset buttons. I have no complaints with the Cooper GCFI outlets I have, they seem to function as they should.
surrogate is offline   Reply With Quote
Old 06-22-2009, 06:43 PM   #3
Rewards Points: 278
I am hoping the fridge outlet will not be downstream of GFCI, I have a regular outlet there, but I heard fridges can trip the GFCI and ruin the food?
As far as code goes does kitchen outlets just need to be CFCI protected via down stream and not at each individual outlet?
Old 06-22-2009, 07:22 PM   #4
DIYer
I bet they all draw about 1 watt constantly.
I was the one who did the experiment, and it was with a cheap harbor freight GFCI which pulled 1 watt. If someone could test more brands, that would be great. Be careful, they surge enough amps to blow the fuse in a meter when they turn on... I found that out the hard way.
Gigs is offline   Reply With Quote
Old 06-22-2009, 07:50 PM   #5
I like the LED lights, lets me tell at a glance there is power
If you are going to install all GFCI's then pigtail at the LINE & run power to each outlet. Do not use the LOAD connections
Pic on the right
Old 06-22-2009, 07:58 PM   #6
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
You can bypass GFCI protecting your refrigerator by using the line side only terminals of the GFCI device.
Cooper, Leviton, same thing. Hubbell GFI's are the best but they don't sell them at HD.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 06-22-2009, 07:59 PM   #7
DIYer
The code only cares that its protected, it doesn't matter where that protection comes from.
There may be some cases where it's easier to wire all the ones that need to be protected as GFCI, such as if you want one to not be protected. An expensive, but easy option. Also if one trips you don't have to hunt.
Old 06-22-2009, 08:17 PM   #8
Rewards Points: 278
Thanks, I did not know you can do this, one of the things is I do not really want to find what is downstream of what.
So I am assuming there is 2 holes on the "line side" to insert 2 wires each, and the clamp will tighten both of them?
Pic on the right
Old 06-22-2009, 08:19 PM   #9
I have Levitron & they have 2 holes for 2 wires
Old 06-22-2009, 08:21 PM   #10
DIYer
There usually is.
Old 06-22-2009, 08:29 PM   #11
Home Remodeler
Rewards Points: 164
My Coopers only light when the GFI is tripped.
mikey48 is offline   Reply With Quote
Old 06-22-2009, 08:31 PM   #12
Is it a red light on trip then?
Mine is a green light
Old 06-22-2009, 08:39 PM   #13
replacing [all] five reg. receptacles w. GFCI
I read some of these one draws 1W constantly? [I am going to replace all regular receptacles in the kitchen with GFCI.. all 5 of them. (yes I understand downstream is protected already, but it looks more professional)]
Not only is it unnecessary. As you stated yourself. "I understand that all the outlets downstream are protected already". It won't work! I've straightened out jobs where someone tried what you suggested. As far as the brand. I believe (generally) all Leviton products are of a higher quality than some of the other brands!Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 06-22-2009, 08:44 PM   #14
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
See, now I feel the opposite.
Leviton's resi grade stuff is basically junk IMO. ESPECIALLY their GFIs. I can't stand them.
I have gone to Cooper for pretty much all my devices and cord caps. I think the quality is great.
As far as spec grade stuff both are acceptable.
I use mostly spec grade receptacles and resi grade switches.
Old 06-22-2009, 08:47 PM   #15
Originally Posted by mikey48 View Post
[My Coopers only light when the GFI is tripped.]
Different brands (and time of manufacture) will light for different reasons. Some will light only when miswired. (light/load switched around) Others will light when wired correctly!Don't Drink and Drive!!!
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 08:53 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
