Converting 12v To 110v - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 12:53 PM   #1
Converting 12v to 110v
I have an electric boat winch that I'd like to use as a winch to lift the top of my jeep off in my garage. How do I convert the 12v winch to work in my garage?
DCSPRY is offline   Reply With Quote
Old 05-18-2010, 12:58 PM   #2
Master Electrician
Rewards Points: 5,082
Use a 12 volt battery.
brric is offline   Reply With Quote
Old 05-18-2010, 01:52 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
or a 120 VAC to 12 VDC inverter.
Old 05-18-2010, 01:57 PM   #4
plug it into your cigarette lighter
The older I get the better I was
Old 05-18-2010, 02:49 PM   #5
How many amps does it pull? If it's 150A @ full load this could get messy.
How much does your jeep top weigh? Lifting 100# 6' in 10 seconds is only 0.1 hp. A regular car battery wouldn't mind this amp draw for a short while. If you do this, use jumper cables direct to the battery terminals; we don't want fuses in this circuit.
Old 05-18-2010, 03:10 PM   #6
Connect it to the Jeep's battery with jumper cables.
hayewe farm is offline   Reply With Quote
Old 05-18-2010, 04:50 PM   #7
and if you don't have an ammeter to check current draw, use your dome light.
The starter motor takes about 200A and dims the light because the battery does not have zero internal resistance.
The dimming while lifting the top can then be judged and compared to the 200A draw.
Converting 220v dryer to 110v dbielinski Appliances 17 09-05-2012 05:45 PM
Adding 110V outlets to 220V line MarcG Electrical 25 04-29-2009 06:04 AM
converting from 220v to 110v steven h Electrical 7 11-16-2008 07:27 PM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 11:55 AM
110v 50hz dev Electrical 4 04-01-2007 09:56 PM
