Converting 1 Tv Coxial Lead To 2 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 02:22 PM   #1
Talking
Converting 1 tv coxial lead to 2
i'm trying to re-wire a tv cable behind a wall, i need to make a single cable fit a double socket box thingy. i tried to cut back to the copper wire and twist it all together, then electrical tape it. but i was told the tv would get interference! any help floating about?
Bramwell is offline   Reply With Quote
Old 06-07-2009, 02:47 PM   #2
300zx's Avatar
Post
Step 1
Separate the wires that are to be tied together.
Step 2
Strip approximately -inch to 3/8-inch of insulation off each wire. This should be enough to fit into the wire connector.
Step 3
Insert all the wires into the center of the connector.
Step 4
Twist the connector around the wires until they bottom out in the connector.
Step 5
Check to make sure each wire is securely in place and will not pull out when tugging on the wire. Use a Splitter to make 2
300zx is offline   Reply With Quote
Old 06-07-2009, 02:52 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I noticed the OP is not in the states. I do not know if they use the same connectors as we do here with coax so:
bramwell, if the info 300zx gave you answers your questions, great. If it doesn't say so and we'll try to figure out the fix for those in England.
Old 06-07-2009, 04:29 PM   #4
Thumbs up
Thank-you
Cheers fella's it makes complete sense, i think its the same in england, thank you
Old 06-07-2009, 04:53 PM   #5
nap
You talking to me?
nap's Avatar
great. best of luck with the project
Flaking lead paint on plaster - skim coat? sabernar Remodeling 1 05-05-2009 06:49 AM
Lead based paint jenikahula General DIY Discussions 3 03-10-2009 12:08 PM
What are the extra lead pipes for??? crazytank7 Plumbing 9 12-06-2008 01:58 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
Lead on/in the walls diylady Painting 4 12-09-2007 10:19 PM
