Control Outlet With Switch - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joed
Old 11-10-2017, 02:14 PM   #1
Control outlet with switch
Hello! I need help please! I have a switch that should be controlling an outlet so I can turn the lamp on and off but the problem is that it is always hot.
The pictures for the switch are 1 and 2 attached
The pictures for the outlet are 3,4,5,6 attached
I know that I need to connect the red to the outlet so it only goes hot when the switch is on but I tried that and disconnected the black and it doesn't work. There are 3 sources going into the box for the outlet, one on the right and two on the left. The two on the left has one hidden behind it that has black, white, and ground coming out, and the one in front that can be seen has black, white, red, and ground. Assuming black and red are hot and white is neutral, how could I connect the outlet to get the switch to work. I think there are also other outlets that the red line goes through but the power is being passed down. Thank you!
Control outlet with switch-1.jpeg   Control outlet with switch-2.jpeg   Control outlet with switch-3.jpeg   Control outlet with switch-4.jpeg   Control outlet with switch-5.jpeg
goku7310 is offline   Reply With Quote
Old 11-10-2017, 02:23 PM   #2
Deleted Member
Shadow99's Avatar
Rewards Points: 1,080
Re: Control outlet with switch
looks like only one hot for it
Shadow99 is offline   Reply With Quote
Old 11-10-2017, 02:25 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,904
Looks like you have a three way switch with a switch loop.
At the receptacle you have a white connected with some blacks. You need to take the black that comes from the same cable as the white and connect that to the receptacle gold screw. If you want the whole receptacle (both plugs) switched then you need to remove the black pigtail.
If you only want half the receptacle switched then you need to remove the tab between the two gold screws.
47_47 likes this.
The Following User Says Thank You to joed For This Useful Post:
goku7310 (11-10-2017)
Old 11-10-2017, 03:38 PM   #4
Thanks a lot Joe!
But still need some help, the switch works now as it wasn't before, but the problem is now the switch controls ALL of the outlets in my living room, 4 of them. So when I turn it off the whole living room has no power. Anything else I can do?
Old 11-10-2017, 03:49 PM   #5
Super Moderator
joed's Avatar
Tell me exactly what you did.
Old 11-10-2017, 04:44 PM   #6
I didn't do exactly as you told me to because my brain isn't working today but I used the correct black wire you were talking about and it worked! Thanks SO much. But should I just leave the red wire capped like that or does it connect to anything else?
Old 11-10-2017, 04:51 PM   #7
Super Moderator
joed's Avatar
If everything is working leave it.
There should be another switch since the you posted is a three way. The red could be part of the three way. It appears to be connected to a black.
goku7310 (11-13-2017)
Old 11-10-2017, 05:39 PM   #8
hkstroud's Avatar
Rewards Points: 6,692
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 11-13-2017, 12:09 AM   #9
Thanks A LOT for the help Joe! I left the red wire capped like that. It is a three way switch and the second switch that controls the outlet is literally 5 feet from the first. whoever designed it must have been one lazy individual. one One last question. Since it looks like the three way setup goes through the whole living room, is it possible to make switch 2 control another outlet in the future?
Old 11-13-2017, 09:16 AM   #10
Super Moderator
joed's Avatar
Possibly, but you would probably need run some new cable.
replace switch that control an outlet with an outlet CarsonKT Electrical 5 08-06-2017 03:02 PM
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Wall switch to control outlet JustScrewIt Electrical 4 01-18-2016 11:40 AM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
