Connector Type? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Yodaman
Old 11-26-2016, 11:40 AM   #1
Rewards Points: 863
Connector Type?
I am not sure what type of connector this is. I would like to separate it but can't figure out how. Any help will be appreciated.
I need to separate the connector so I can put the connectors (two) through a small hole in the metal piece in the photo. One goes through, but I can't fit the second one without separating it.
Connector Type?-img_20161126_085221.jpg   Connector Type?-img_20161126_085227.jpg   Connector Type?-img_20161126_085258.jpg
greentrees is offline   Reply With Quote
Old 11-26-2016, 12:12 PM   #2
Property Mgt/Maint
Rewards Points: 8,184
Re: Connector Type?
Try a universal disconnect tool.
Some of those little connectors can be a PITA
MTN REMODEL LLC and de-nagorg like this.
Yodaman is offline   Reply With Quote
Old 11-26-2016, 12:28 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,596
Re: Connector Type?
It just snaps together. flex and pull or pry the tabs with a small screwdriver to release them.
Old 11-26-2016, 08:27 PM   #4
Licensed electrician
Rewards Points: 3,766
Re: Connector Type?
Might also try a push and twist motion .
Old 11-26-2016, 08:59 PM   #5
Rewards Points: 1,956
Re: Connector Type?
In the fat part of the connector I see a tab there, I think you lift up on it with a small flat screwdriver while pulling the two skinny ends apart.
ChuckF. is offline   Reply With Quote
Old 11-27-2016, 12:32 AM   #6
Rewards Points: 863
Re: Connector Type?
Tried the push and twist but it didn't budge. Used a pair of pliers and squeezed the plastic a bit and tried to pull it apart, it didn't budge. I got a safety pin and pushed it in the sides but it didn't do much. I put the safety pin near the tab and pushed down, and it opened a gap. I pulled and it came apart.
I think there was some ridge that the connector was sitting on and by pushing down it released it.
I got the fan light connected to the fan, but for some reason the lights didn't come on. I'll need to take it apart again and check to see if voltage is coming to the connectors that I hooked the lights up to.
Might be another post about how to connect fan lights
Connector Type?-img_20161126_195251.jpg   Connector Type?-img_20161126_195436.jpg
Old 11-27-2016, 07:54 AM   #7
Re: Connector Type?
The connection under the fan canopy may need to be made.
Old 11-27-2016, 11:16 AM   #8
Rewards Points: 863
Re: Connector Type?
I checked the power going to the wires and they are live. I think the unit is bad, so I am returning it and getting a replacement. I found out I have a separate light switch for the fan and the lights, so that is a good thing. I thought I might have only one switch set up.
