Connecting Two Ground Buses. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 07:54 PM   #1
Connecting two ground buses.
Hi All,
New member here with what I hope is a quick question. I'm running 100A power to my new shop. It's a four wire unbonded subpanel. I picked up a square D homelite box and it appears there is no way to separate the neutral buses that came with the box. I went ahead and picked up two extra ground buses and have them installed in the box. Is the a proper way to connect the two ground buses together? I had planned on connecting the ground coming in from the main to one of the buses and then running the ground wire the goes the the ground rod through one bus and then over to the other. Is there a better way?
Thanks in advance,
Dave
tgidave is offline   Reply With Quote
Old 06-30-2010, 07:59 PM   #2
Licensed electrician
Rewards Points: 3,662
The add on ground buss just screw into the raised bosses on the back of the enclosure. No need to run any wires between them.
Old 06-30-2010, 08:22 PM   #3
Thanks, Jim, that what I needed to know. Like I said, I was hoping it was an easy one...
Dave
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Lost my Ground jodywoj Electrical 10 12-20-2009 06:37 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
12v DC ground to chassis ground of a 120V appliance? pcampbell Electrical 12 02-17-2009 09:24 PM
