Confused - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2019, 08:51 PM   #1
jd2
Rewards Points: 14
Confused
Have 230 volt 3hp 1ph 230 volt motor drawing 15 amps operating a vacuum. Manual says run a 40 amp dedicated circuit. Problem is the motor has a 20 amp 230v plug. Distributor recommended wire nut a 20 amp receptacle to the # 8 thhn, I don't think so. My question is, if I cut the plug, staight wire motor lead into jbox with the #8 thhn, what would the amperage rating on a disconnect be?
Sent from my SAMSUNG-SM-T807A using Tapatalk
jd2 is offline   Reply With Quote
Old 04-24-2019, 09:24 PM   #2
Rewards Points: 4,388
Re: Confused
Duplicate post: https://www.diychatroom.com/f18/confused-657915/
stick\shift is offline   Reply With Quote
Old 04-24-2019, 09:34 PM   #3
Rewards Points: 58
Is the power cord on the vacuum factory? Bought it new?
Wiredindallas is offline   Reply With Quote
Old 04-25-2019, 08:20 AM   #4
Deleted Member
Shadow99's Avatar
Rewards Points: 1,030
Re: Confused
Take a second look at the manual.
I'd think that the whole circuit would be wired with #12, with a 40A breaker.
Just leave the plug on the unit as well.
Shadow99 is offline   Reply With Quote
Old 04-25-2019, 11:52 AM   #5
jd2
Rewards Points: 14
Re: Confused
Yes, new machine, original cord
Sent from my SM-G955U using Tapatalk
Old 04-25-2019, 07:42 PM   #6
jd2
Rewards Points: 14
Re: Confused
Taken from manual. At the moment I have #12 thhn connected to 20 amp 230 volt receptacle with 30 amp breaker. Length of run is approximately 70 feet. Working fine for now.
Confused about fence post concretes d189379 Landscaping & Lawn Care 12 09-27-2014 12:50 PM
Utterly confused - air barriers when finishing attic? s2m Insulation 5 12-11-2012 11:28 PM
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
Trying to wire my bathroom... confused... Alan Electrical 3 11-23-2008 05:44 PM
