Confused - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2019, 07:38 PM   #1
jd2
Rewards Points: 14
Confused
Have 230 volt 3hp 1ph 230 volt motor drawing 15 amps operating a vacuum. Manual says run a 40 amp dedicated circuit. Problem is the motor has a 20 amp 230v plug. Distributor recommended wire nut a 20 amp receptacle to the # 8 thhn, I don't think so. My question is, if I cut the plug, staight wire motor lead into jbox with the #8 thhn, what would the amperage rating on a disconnect be?
Sent from my SAMSUNG-SM-T807A using Tapatalk
jd2 is offline   Reply With Quote
Old 04-24-2019, 08:25 PM   #2
Rewards Points: 3,950
Re: Confused
Can you not accommodate this?
stick\shift is online now   Reply With Quote
Old 04-24-2019, 08:27 PM   #3
Re: Confused
Sorry, dup....
Confused on Attic Insulation in Cape Cod style centro7710 Insulation 2 06-14-2016 06:11 AM
Confused about fence post concretes d189379 Landscaping & Lawn Care 12 09-27-2014 11:50 AM
Utterly confused - air barriers when finishing attic? s2m Insulation 5 12-11-2012 10:28 PM
Yes another basement insulation question...confused jdtox Insulation 5 10-15-2012 01:48 PM
Confused about Sub Panel stqevo Electrical 28 10-01-2009 11:04 PM
