DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Confused (https://www.diychatroom.com/f18/confused-657915/)
jd2 04-24-2019 07:38 PM
Confused
Have 230 volt 3hp 1ph 230 volt motor drawing 15 amps operating a vacuum. Manual says run a 40 amp dedicated circuit. Problem is the motor has a 20 amp 230v plug. Distributor recommended wire nut a 20 amp receptacle to the # 8 thhn, I don't think so. My question is, if I cut the plug, staight wire motor lead into jbox with the #8 thhn, what would the amperage rating on a disconnect be?
Sent from my SAMSUNG-SM-T807A using Tapatalk
stick\shift 04-24-2019 08:25 PM
Re: Confused
Can you not accommodate this?
stick\shift 04-24-2019 08:27 PM
Re: Confused
Sorry, dup....
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
