Confused On A 3 Prong 230 Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 10:29 PM   #1
confused on a 3 prong 230 plug
i bought a hobart female plug to hook up to my power wire that comes out of my breaker box so i can plug my welder up.it has 2 straight one short one long then it has the round one to. ok my wire from the box has 4 wires 1 black/1 white/1 red/1 bare copper ground how do i hook it up to the plug.i guess i need to know what wire goes to the short straight plug and so on. thanks
vinylman70 is offline   Reply With Quote
Old 01-30-2010, 10:48 PM   #2
Electrical Contractor
kbsparky's Avatar
You don't need the white wire on a straight 240 Volt welder circuit.
The black and red wires connect to the straight blades on the plug. The green to the round ground pin. No connection for the white.
-KB
Old 01-30-2010, 11:24 PM   #3
i understand you on that but i dont have a green wire the red and black are connected to the 30a breaker then the copper wire to the ground side where the small screws are then the white on the other side where the small screws are. so instead of connecting the green to the green screw on the round plug would i just connect the copper wire instead since it is the ground. then does it matter what straight has the black or red? then on the white would i just cut it off and not use it. thanks
Old 01-31-2010, 07:11 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
What input amperage is this welder?
What size wire is the "power wire that comes out of my breaker box"? And what do you mean by that?
I get the impression that you don't have much experience doing this stuff. Are you absolutely sure what you are doing is right?
Old 01-31-2010, 08:48 AM   #5
welder is 25-185 ampers/230volts the wire says 3 color awg8/awg10g 600v my dad is the one who wired everything he does not live here anymore now i have to finish it my self.
Old 01-31-2010, 09:00 AM   #6
INPUT amperage. Not output.
Old 01-31-2010, 10:05 AM   #7
it says max is 31 the power supply is hooked to a 30 amp breaker
Old 02-01-2010, 07:06 AM   #8
kbsparky's Avatar
Also, it would appear we need to know the input VOLTAGE.
Is it possible to post a picture of the unit's nameplate? This could help immensely.
-KB
Old 02-01-2010, 08:17 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,536
Ayuh,... That's Right...
No, it doesn't matter which goes to what side...Each is 110v to make 220v for the welder to work...
Bondo is online now   Reply With Quote
Old 02-02-2010, 12:06 AM   #10
the welder is a hobart 187 if that helps the box in the shop is a 200 amp box but i am only running 100amp to it from the house under ground the electrician that will be digging the trench and hooking up the wire at the house and shop is useing only 3 wires of 3 guage alluminum wire. then will be installing grounding rods in the ground from the box at the shop.i went ahead and hooked the black and red wires to the straight plugs and the bare copper wire to the round plug and just cut the white wire so it wont touch any thing and also disconnected the white wire in the box to.also he had the red,black wires hooked to the 30a breaker with the copper wire hooked up as ground this should be right. right ?? thanks
3 wire with ground to 3 prong dryer plug dgbunk Electrical 9 10-19-2010 01:07 PM
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 10:30 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 12:59 PM
