A Confirmation On My Switch Box Hook Up. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 11:37 AM   #1
Rewards Points: 145
A confirmation on my switch box hook up.
Since I'm still a little new at this I like to run through any thing past the most very basic on the forum here, just want a confirmation shout out:
Scenario:
15amp/ 14/2 Romex
One source in to double switchbox, regular single pole switches, each to a separate fixture, plus one through power to another location.
1) the source black and powerthrough black nutted with 6" pigtails to to both switches.
2) blacks going out to light fixtures connected to their respective switches.
3) all whites nutted together, including white on the "through line"
4) all grounds nutted together with pigtails to the switches' ground nuts
Do I have it right?
THANKS IN ADVANCE!!
James
DiegoJames is offline   Reply With Quote
Old 07-03-2013, 12:13 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,690
Originally Posted by DiegoJames View Post
...(feed) in to 2gang J-box, 2 SP switches,
plus one through power to another (lighting) location.
4) all grounds nutted together with pigtails for the two switches
(always do the Ground and Neutrals first...
get 'em out of your way and tucked into the back of the box
1) (feed) and power through black nutted with 6" pigtails to both switches.
2) (switch loop) blacks to their respective switches.
Do I have it right?
Yep. And I bet it even works too.
The Following User Says Thank You to TarheelTerp For This Useful Post:
DiegoJames (07-03-2013)
Old 07-03-2013, 01:33 PM   #3
Rewards Points: 145
Thanks TarheelTerp. Also for your added correct terminology and extra words of advice.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
