Conduit Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 09:35 PM   #1
Conduit requirements
Was at Home Depot tonight and guy there says that metal conduit (EMT) is needed to run conductors from a subpanel to the ground on an outside panel. Says can be PVC once underground but needs metal from bend or underground to panel. Is this true?
was told previously (and was planning) to have PVC from panel to ground and run underground to my hot tub and a small shed.
is metal required or is schedule 40 kosher?
MeanGene is offline   Reply With Quote
Old 11-04-2010, 10:18 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
pvc is fine but if it is subject to damage, you would need to use schedule 80, not 40.
Old 11-05-2010, 07:56 AM   #3
thanks so much...thats what I thought.... in low traffic, nothing hits area so should be good.
Is metal conduit required between main panel and subpanel? only 1 foot apart.
Old 11-05-2010, 10:26 AM   #4
Rewards Points: 308
Be careful. Some jurisdictions may require that you use ridged metal conduit for stubbing up out of the ground. EMT would be the last thing I would use for this. Just my opinion, as EMT can be buried, but will be rusted out in no time. Check with your local code or building dept before proceeding.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
