Conduit Reducer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2012, 06:46 PM   #1
Rewards Points: 248
conduit reducer
If you have two sizes of pvc conduit, say 2" and 3", can you use a reducer of some sort?
jackwashere is offline   Reply With Quote
Old 02-10-2012, 06:55 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,014
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yes you just buy a reducing coupling or a bushing. What is the reason for reducing the size?
rrolleston is offline   Reply With Quote
Old 02-10-2012, 07:48 PM   #3
I would install a junction box between the two. Using a reducer may cause a problem to fish!
Old 02-10-2012, 07:54 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Then get 3 inch PVC C conduit body and instert 2 to 3 inch reducer on one end so that way you can see and catch the fishtape there.
So that is one of few idea you can try.
Simuair to this photo but get one in 3 inch verison this useally found in electrical supply centre, but big box store it kinda semi long shot so I will say 50/50 they may have it or not.
Merci,
Marc
Old 02-10-2012, 08:03 PM   #5
rrolleston's Avatar
Merci,
Marc
Good call. Most likely will have to go to electric supply because big box stores usually hard to find anything over 2"
The Following User Says Thank You to rrolleston For This Useful Post:
frenchelectrican (02-10-2012)
Old 02-14-2012, 06:35 PM   #6
Rewards Points: 248
I buy material on craigslist whenever possible. I might pay %20-40 of retail cost but 50 sticks might be 2 inch and 50 sticks might be 3 inch.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
