Conduit Or Not In Cook County, Illinois? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2014, 11:54 PM   #1
Conduit or not in Cook County, Illinois?
Hi all, this is my first post. I want to install a ceiling fan in our bedroom which has no electrical box in the ceiling. I have attic access above the bedroom to install a ceiling fan electric box bracket and also have access to electrical boxes to tap electric from to supply the ceiling fan. My question is do I have to run the new wiring (approx. a 15 foot run) in thin wall metal conduit or can I use BX for this? Many thanks to anyone that can help me out with this. Located in Wheeling, IL which is Cook County.
mjchevalier is offline   Reply With Quote
Old 06-21-2014, 04:55 PM   #2
After an evening of no posts on my question, I thought maybe I should clarify my situation and what I am trying to accomplish. I want to put a ceiling fan in our bedroom which has no electrical box in the ceiling. I live near Chicago with the same code as Chicago uses. Can I install this ceiling fan to a joist in the ceiling and run external wiring to a live outlet to supply the power for it, and still be within code? I was thinking about a swag kit or some type of cable raceway. Please let me know because I am in the dark on this. Thank you very much!
Old 06-21-2014, 05:06 PM   #3
Electrical Contractor
kbsparky's Avatar
I have no clue about the rules in Chicago, except they require conduit for everything.
Not sure about the use of MC or Bx cable, or even greenfield ....
-KB
Old 06-21-2014, 05:53 PM   #4
Sparky
Rewards Points: 510
Greenfield(FMC) is only allowed in lengths 6' or less.
Chapter 3 Articles for NM, UF, AC, and MC have been completely deleted, so no use of those at all.
Looks like EMT is the easiest legal way.
Source. https://library.municode.com/index.aspx?clientId=16690
Techy is offline   Reply With Quote
Old 06-21-2014, 11:13 PM   #5
Rewards Points: 173
This sounds correct. I used to live in Cook County and had to deal with this a couple times - BX is allowed but only for short runs. I think I recall the threshold being something like 5 or 6 feet as Techy said.
To the OP - EMT is the only code-compliant option for you. However, it can be DIY friendly if you have basic electrical capabilities and access to a bender - you can also buy the pre-formed bends for a little extra $$.
MrBryan is offline   Reply With Quote
Old 06-22-2014, 07:46 PM   #6
Dave Sal's Avatar
Rewards Points: 646
I had the same dilemma about 25 years ago. Bought a Casablanca ceiling fan for the bedroom but the was no box on the ceiling. I bought a braced electrical box and ran BX cable to the nearest junction in the attic. It's worked perfectly ever since.
Dave Sal is offline   Reply With Quote
Old 06-22-2014, 09:22 PM   #7
Rewards Points: 1,306
Mandatory EMT. Sorry. I live in IL too. Some say it's driven by union electrical workers others say the fire department.
Either way it puts an enormous cost burden on simple residential construction. It's right up there with fire sprinklers in single family residential.... Burden 100% of homes for fire that may hit one in 10,000... Nuts.
curiousB is offline   Reply With Quote
Old 06-23-2014, 07:54 PM   #8
Is this true?. I thought they relaxed length limits if greater than 3/8" FMC? Further if you run separate ground conductor there is no length restriction. I don't know just wondering what the experts say NEC states.
Old 06-23-2014, 09:36 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It's a well known fact that the house will burn to the ground if you use any sort of cable in a dwelling located in the Chicago area.
I try to be as code compliant as I possibly can, but some stuff is just stupid.
The Following User Says Thank You to k_buz For This Useful Post:
Dave Sal (06-24-2014)
Old 06-23-2014, 10:32 PM   #10
Originally Posted by k_buz
It's a well known fact that the house will burn to the ground if you use any sort of cable in a dwelling located in the Chicago area. I try to be as code compliant as I possibly can, but some stuff is just stupid.
Amen. You'd think with 40+ years of data across millions of homes and no statistically higher electrical driven fires than elsewhere in the USA someone would say "maybe this is a dumb rule".
Old 06-24-2014, 06:18 PM   #11
Sparky
Rewards Points: 510
The NEC doesnt have any length restrictions on other than 3/8" flex, and the requirement for a wire type EGC after 6'.
Chicago area code amendments are a completely different animal
Old 06-24-2014, 10:04 PM   #12
Msradell's Avatar
Rewards Points: 1,140
Which of those choices do you think worked to get conduit mandatory? Considering the unions run everything else in Chicago including city government I think it's pretty clear.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Tags
bx wiring , ceiling fan , chicago , code , conduit
Conduit Attached to Exterior Foundation rjschwar Electrical 0 07-14-2012 02:14 PM
Correct cable for 10/2 in NM conduit greg619 Electrical 18 05-10-2012 11:12 AM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
dradford white water heater wholesalers in lake county illinois john arazan Plumbing 1 10-27-2010 12:59 PM
Cook County Grounding rules McSweny1103 Electrical 30 08-11-2010 07:13 PM
