Compressor To Wire Up - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 02:08 PM   #1
Compressor to wire up
i have a compresser that needs wiring up. The trouble is there is a brown and blue wire together but blue is net and brown is live so how do you wire them into a on and off switch
m chauhan is offline   Reply With Quote
Old 03-10-2010, 08:34 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Ok due this colour format this is not a normal North Americian set up and I am used to the European system { I am in France }
Ok to order to get your compressor switch working properly do your compressor have pressure switch there ? or just a tail { short cable } hanging loose ?
With European verison of pressure switch you should see R and T or L1 and L2 one or A and B one of three combations that one part is line and you will see second termail for load side that for pressure switch set up
However if you have isolation switch then it will be little diffrent with isolating switch the bleu is wirenuted or chocblocked together then take brown { live } to first screw of switch then second brown to the pressure switch or motour if need to be { make sure you have working pressure switch on this }
If more question just holler
Merci,Marc
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
