Complete The Loop? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 03:53 PM   #1
just a dude
Rewards Points: 34
Complete the loop?
I am removing a light fixture in my barn to use it somewhere else. I won't be replacing it right away. Do I nut all of the wires together? It's at the end of the circuit.
Thanks,
Rob
rocklobster is offline   Reply With Quote
Old 11-26-2010, 04:07 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 704
Put a wire nut (or electrical tape) on each of the 2 wires connected to the fixture. Do not connect them together. If there any other wires in the box, leave them alone.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-26-2010, 04:14 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I assume that by "It's at the end of the circuit"
that there is one hot and one neutral connection that were connected to the light fixture wires.
Wire nut each wire separately. I hope you did not mean to wire nut the Hot & Neutral together.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-26-2010, 08:27 PM   #4
just a dude
Rewards Points: 34
Got it worked out. I didn't mean to do anything without looking into it first, and you gave me the answers I needed. Thank you.
Rob
Old 11-26-2010, 10:15 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
You need to put a blank cover on the junction box, if there is one. If there isn't, you would need to install one or disconnect the wire from where it feeds from.
How do you use a loop roller? redline Painting 8 04-02-2013 09:05 AM
Changing valve near boiler loop secutanudu Plumbing 10 09-29-2010 09:50 PM
Recircluating Loop CKSedg Plumbing 7 03-12-2010 04:46 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 06:04 PM
