Compact GFCI's?? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2010, 10:52 PM   #1
Rewards Points: 152
Compact GFCI's??
My house is old with ungrounded outlets. I want to put GFCIs to make the ground. My problem is that GFCIs are really thick and i know ill have problems with some outlets that have a bunch of wire, not much space of installing those thick GFCIs inside the box.
I want to know if stores sell compact GFCIs. The regular GFCIs are really thick and ill have problems trying to install them with some outlets that have lots of wires
humberguy is offline   Reply With Quote
Old 06-09-2010, 07:53 AM   #2
I've never seen a "thin" GFCI
GFCI breaker would be a better option
Old 06-09-2010, 07:56 AM   #3
Just call me Andrew
Rewards Points: 1,032
Not sure on your exact question (compact GFCIs) but you also need to be concerned with box fill. Take a look at this site .
Also, on a technical note, a GFCI does not provide a ground. It does provide similar protection by cutting the circuit from the GFCI onward if there is a current leak. A current leak to an equipment grounding conductor usually trips the breaker.
Good call on the GFCI breaker, Dave.
Andrew
secutanudu is offline   Reply With Quote
Old 06-09-2010, 07:59 AM   #4
Correct, GFCI does not provide a ground
But it does allow you to install a 3 prong outlet instead of the 2 prong
That is the reason most people want to install the GFCI's on older houses
Outlets must be marked - no ground present
I prefer to always have a ground
But can be $$ to replace wiring
Old 06-09-2010, 07:59 AM   #5
Originally Posted by humberguy View Post
My house is old with ungrounded outlets. I want to put GFCIs to make the ground....
GFCIs on an ungrounded circuit don't "make a ground", fyi. It will allow you to plug in some certain 3 prong plugged appliances like fans where you will gain some protection. Electronics like computers should not be plugged into them as they require a "real" ground.
If you can put a GFCI at the start of your circuit, the other outlets can be put on the load side of it and you will gain protection that way. Make sure you read the instructions that come with the GFCI plug and put the "No Equipment Ground" stickers on the rest.
(I'm no electrician btw, so this is only my advice I've picked up.)
tdeg807 is offline   Reply With Quote
Old 06-09-2010, 08:38 AM   #6
And if the OP has a jumper wire and a DVM that can show the difference between .01 ohm and .02 ohm he can find which outlets are downstream of which other ones.
How much will road base compact? jbdkisner Landscaping & Lawn Care 2 02-04-2010 06:10 PM
Wiring GFCI's in kitchen and baths Mike2181 Electrical 16 11-01-2009 02:39 PM
compact burgundy shrub that doesn't lose its leaves in winter joshoc Landscaping & Lawn Care 12 09-27-2009 10:42 AM
Do I need to compact with this situation? KUIPORNG Landscaping & Lawn Care 1 06-19-2008 03:11 PM
Multiple GFCI's Bob C. Electrical 7 02-28-2004 10:20 PM
