Cold In Canada - Electrical - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 06:06 AM   #1
cold in canada
I am trying to wire in a 240 baseboard heater into a bunkie. The subpanel in the bunkie is fed by 12/3 from the main cottage running off a 40 amp breaker. The subpanel currently also runs lights and 2 plugs. I have run 12/2 wire from the heater to the subpanel, but now i am stumped. Help? Thanks.
cottageguy is offline   Reply With Quote
Old 02-15-2010, 08:06 AM   #2
Electrician
Rewards Points: 910
First thing would be to change the 40A breaker to a 20A breaker, #12 is only good for 20A.
Does your heater have a build in thermostat, if not how do you plan on controlling the heater.
darren is online now   Reply With Quote
Old 02-15-2010, 08:54 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 24,052
How big is the heater? That #12 wire is probably too small for this. It must be protected by a 20 amp breaker. Change the 40 amp out ASAP.
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
