Code For Bathroom Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 12:13 PM   #1
Rewards Points: 83
Code for bathroom outlets
So I know an outlet in a bathroom near a sink needs to be GFCI protected since it is within 3 feet of the sink, but usually the light switch is not wired into the GFCI outlet, is there a distance requirement from the sink to outlet, like needs to be at least 3 feet away for a light switch? or even in the kitchen sink for that matter, or is there no code issue for distance from sink to light switch?
streetneons is offline   Reply With Quote
Old 02-16-2014, 01:01 PM   #2
Licensed electrician
Rewards Points: 3,766
Switches do not need GFI protection. There is no required distance from a water source, They cannot be above or inside the footprint of a tub or shower.
ben's plumbing (02-16-2014)
Old 02-16-2014, 01:09 PM   #3
Rewards Points: 3,396
agreed............but can be right up to it.
from what I understand this is true... although some inspectors may want it protected if in close proximity to shower/bath and have a plastic plate and screws.....
Now if memory serves me correctly...there is a distance for a switch and jaccuzzi..
ritelec is offline   Reply With Quote
Old 02-16-2014, 03:46 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This is the problem, what inspectors WANT vs what is required...
Replacing older outlets kah5683 Electrical 11 05-11-2013 10:45 AM
Can I have GFCI Outlets on same circut as normal outlets? 12/2 cloves Electrical 31 05-08-2013 10:22 AM
One by one all outlets in house go dead Sheeblee Electrical 5 08-23-2011 09:22 PM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
no cover plate outlets, code? DangerMouse Electrical 17 01-03-2009 11:14 PM
