Clothes Dryer Relocation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 08:01 AM   #1
I would like to relocate my dryer to my basement. Pulling a new 10/3 line will be a major undertaking. I can access the 10/3 line that runs to the current laundry room outlet. Is it code compliant to jbox a 10/3 line? I would only keep 1 of the outlets hot. Thank you.
jsetche is offline   Reply With Quote
Old 12-24-2010, 08:05 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Remove the receptacle, add the new wire to the new location, and put a blank cover over the box.
The box has to remain assessable.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 12-24-2010, 08:05 AM   #3
Just call me Andrew
Rewards Points: 1,032
So you want to extend the existing circuit by converting the current outlet box into a j-box, right? I don't see that as a problem as long as appropriate wire connectors are used and securely fastened.
You the cable you are using has 3 wires + ground, right?
Andrew
secutanudu is offline   Reply With Quote
Old 12-24-2010, 08:33 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Good question.
Old 12-24-2010, 09:58 AM   #5
Follow up
Yes, the current romex is 10/3 with ground (4 wires). Since the current laundry room is on the main level and I can access the wires from the basement, can I make the wire splice in the basement w/ jbox and just leave the old laundry room outlet non-functioning? What I am trying to do is move the laundry to the basement to appease my wife, but be able to reconnect the old outlet should I sell my home, or more likely when my wife wants to move it back to the original location.
Thanks for all the replies!
Old 12-24-2010, 10:02 AM   #6
Just call me Andrew
So, cut the wires in the basement, leave the wire running from the j-box in the basement to the old outlet, but disconnected? That should be ok, but i'd remove the outlet (replace with a blank cover), cap all the wires on both ends and mark them. Also, should you ever decide to reconnect the upstairs outlet, you will need extra slack in the wire to reah your new Jbox in the basement. Both ends of the wire need to extend 6" out of the junction box.
Not sure if i am explaining that clearly...
Andrew
Old 12-24-2010, 10:02 AM   #7
jbfan's Avatar
Rewards Points: 946
That works, but it will be somewhat of a pain to get that cable back into the old box in the furture.
I would take the receptacle out and put a blank cover over the exsisting box.
The Following User Says Thank You to jbfan For This Useful Post:
jsetche (12-24-2010)
Old 12-24-2010, 11:13 AM   #8
Registered User
Rewards Points: 526
Just a side note for safety, new hood vent 3' from other openings to house, windows, doors, furnace air supply (10' minimum), etc.: http://publicecodes.citation.com/ico...002_par002.htm
Gary
Old 12-24-2010, 03:55 PM   #9
You explained it exactly, and just saved me from making a big mistake. I rechecked the existing 10/3 and there is not any slack. Gonna go with the suggestion of making a wire join in the existing outlet box. Thanks.
clothes dryer sucking all my cool air outside shank General DIY Discussions 6 08-02-2012 09:01 PM
Clothes Dryer Ducting Earnie Plumbing 1 11-30-2010 10:38 AM
ge clothes dryer won't shut off chuck789 Appliances 0 10-20-2010 01:02 PM
Relocation of washer and dryer genie Plumbing 2 01-25-2009 02:29 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
