Clarification On PVC Conduit Depth - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 09:57 AM   #1
Clarification on PVC Conduit Depth
Alright,
Everywhere I have read says PVC conduit must be atleast 18 inches deep at the top of the PVC pipe... but I had a electrician come over and tell me it has now changed in the 2008 NEC to 24 inches... can anyone confirm or clarify? I am looking in the NEC I just figured someone that knows it better would know exactly where it is in the NEC
joshvette001 is offline   Reply With Quote
Old 05-09-2010, 03:45 PM   #2
Inspector/Instructor
codeone's Avatar
Depends on the application!
Is it going to be at a residence, under concrete, under a building, under a driveway, encased in concrete, etc?
codeone is offline   Reply With Quote
Old 05-09-2010, 04:20 PM   #3
codeone's Avatar
Maybe this will help.
Old 05-09-2010, 08:00 PM   #4
Rewards Points: 1,016
Ask when you pull your permit to ensure you get the proper answer for your locale and application. To my detached garage/workshop this past year was 18" over the conduit - so dug to a 20" trench depth.
Old 05-09-2010, 08:09 PM   #5
liscenced electrician
Rewards Points: 540
most applications would be 18 inches deep, hasn't changed
i dig mine as low as i can. if im using equipment, ill dig it to 3 feet
jimmy21 is offline   Reply With Quote
Old 05-09-2010, 08:44 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Anything one or two family residential is 18" at the most. Even driveways.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 08:17 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 08:48 AM
