Circuit Breakers Shutting Off - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 08:05 PM   #1
Question
Circuit breakers shutting off
Help! We are having a problem with several of our circuits randomly shutting off. The breakers do not trip and they come back on themselves. They will be off for a few seconds up to a couple hours. Two of them are 220 and two are 110.
suzieshobbyfarm is offline   Reply With Quote
Old 05-31-2010, 08:08 PM   #2
You need to check your connection integrity with a DVM and a 1A [incand. bulb] or a 10A [hair dryer or toaster] load. It's about 5 minutes per outlet. For the 240v you need an elec. dryer or elec. oven.
The default fix would be to tighten the connections at your circuit breakers but watch out for arc-flash.
Old 05-31-2010, 08:11 PM   #3
Is this something I can do or do I need an electrician? How do I do this?
Thanks!
Suzie
Old 05-31-2010, 08:14 PM   #4
Thanks!
Suzie
You need to know how to use a DVM.
If an outlet works with a small lamp but will not power a hair dryer it is likely a bad connection. Run the hair dryer just long enough to see that it works or doesn't work.
Old 05-31-2010, 10:11 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 24,050
Since more than one circuit seems to be involved the problem is most likely on the main. You need to call to POCO and have them check all their connections between the panel and the pole.
Old 05-31-2010, 10:44 PM   #6
Rewards Points: 2,800
Each time it happens, is it the same group of circuits that are affected and all of them at the same time?
Can you make a note of which ones they are? This might reveal that it is one leg of the incoming 120/240 volt circuit that is at fault.
Feel the breakers including the main breaker. Is(are) any of them noticeably warmer than the rest? This is a telltale sign of a loose connection.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-01-2010, 12:11 AM   #7
" Euro " electrician
frenchelectrican's Avatar
You have loose connection first thing is you call the POCO first they will come out and check their side first once that clear up then do the load centre inspection next.
Due you say it will be off for few seconds to couple hours this is very important to call the POCO right now once that done then you may have loose conneciton at the main breaker as well.
Merci,Marc
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 05:00 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 12:34 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
