Circuit Breaker Handle Ties - Electrical - DIY Chatroom Home Improvement Forum
Like Tree8Likes
  • 1 Post By Nealtw
  • 2 Post By rjniles
  • 1 Post By John Snow
  • 1 Post By CodeMatters
  • 1 Post By gpraceman
  • 1 Post By Nealtw
Old 04-09-2019, 12:22 AM   #1
DIY'er
Rewards Points: 73
Question
Our panel has several breakers paired together with handle ties, but the individual breakers do not service the same piece of equipment. It looks like they ran 4 conductor romex to these, so these tied together breakers share a ground and neutral wire. I assume they did this to reduce the total number of lines they had to pull.
We have 5 of these pairs:
  • Dishwasher and Disposal
  • Fridge and Kitchen GFCI #1
  • Washing Machine and Laundry GFCI
  • BR1, BR2, Loft, and 2nd Bathroom Lighting
  • Master BR and Master Bath
Do these breakers really need to be tied together? I've been trying to identify all of the loads on each breaker, but with these paired breakers I haven't been able to do that.
gpraceman is offline   Reply With Quote
Old 04-09-2019, 12:35 AM   #2
retired framer
Rewards Points: 5,886
Re: Circuit Breaker Handle Ties
If you only turn off one and use the other there will be power on the neutral so that is the danger. so when you are doing your shut off list, list them all together with both breaker numbers.
gpraceman likes this.
Do not use flat bottom gables with scissor trusses.
Old 04-09-2019, 03:35 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Yes code requires handle ties on the circuits in question.
To do as you want, turn the breaker off, disconnect the wire on one pole and restore the breaker.
Sent from my RCT6213W22 using Tapatalk
gpraceman and CodeMatters like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-09-2019, 08:16 AM   #4
Rewards Points: 34
Interesting note, handle ties would not be required for those circuits in Canada. Only if both circuits are for the same device or piece of equipment.
CodeMatters likes this.
John Snow is offline   Reply With Quote
Old 04-09-2019, 09:16 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
The NEC started requiring handle ties (or 2 pole breakers) for MWBC some time in the 90s. Reason is if only 1 breaker is off the neutral can still nail you.
Old 04-09-2019, 11:11 AM   #6
retired framer
I have never seen them with out a tie, so I would question that statement. Nope, you are right. son of a gun.
Old 04-09-2019, 12:43 PM   #7
CodeMatters's Avatar
Rewards Points: 7,462
The CEC does require that neutrals in MWBC's be done in such a fashion that
any device can be removed without opening the neutral, ie tails.
When done this way there's little to no of chance of a shock from the (grounded) neutral.
Open neutrals are of course another matter.
As far as the op's original question: I'd suggest following @rjniles advice in post 5.
Nealtw likes this.
CodeMatters is offline   Reply With Quote
Old 04-09-2019, 01:37 PM   #8
DIY'er
Rewards Points: 73
That makes sense.
I am a bit OCD. However, in the grand scheme of things, since the breakers are tied together, all the loads can be listed for both. I wish they would have just run individual lines, as that means securing loads in areas that I am not working in.
Old 04-09-2019, 03:30 PM   #9
DIY'er
Rewards Points: 73
Well, my OCD got the better of me. I went ahead and did just that. Now I know what is on each particular breaker.
Old 04-09-2019, 04:13 PM   #10
retired framer
So now when you you change out a switch, you will just turn them both off
anyway.
Old 04-09-2019, 04:26 PM   #11
DIY'er
Rewards Points: 73
anyway.
Right. lol
Well, if I ever do any rewiring, it would be handy to know what particular loads are on each breaker.
Nealtw likes this.
Old 04-11-2019, 05:32 PM   #12
Rewards Points: 1,304
It would be unwise to remove the handle ties. This could give the false impression these are individual/independent 120vac branch circuits. Someone juggles breakers around in the future and could get both of these breakers onto the same phase thus overloading the neutral.
curiousB is offline   Reply With Quote
Old 04-11-2019, 05:35 PM   #13
DIY'er
Rewards Points: 73
Since it is code to have the handle ties there because of the shared neutral, I do not intend to take them off.
Replace my main panel or main breaker? joe_oklahoma Electrical 16 12-16-2015 12:27 AM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 03:04 PM
Circuit breaker not returning everything to power after switched back on sam112 Electrical 7 02-10-2013 01:48 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
