Change Switched Receptacle To Constant - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2019, 09:32 AM   #1
Rewards Points: 18
Change switched receptacle to constant
Hello, Iím trying to convert a 3 way switched receptacle to constant power. Iíve posted photos of the 2 switches and the receptacle. What needs to be done?
Change switched receptacle to constant-314668ae-bb26-4a31-ae05-938527dcfb2a.jpg   Change switched receptacle to constant-fb46f12f-df2f-4fbe-8c11-0d96233288b6.jpg   Change switched receptacle to constant-b978c893-c259-41fa-a05e-c00ce4d4f6e0.jpeg
Aelk799 is offline   Reply With Quote
Old 04-15-2019, 10:08 AM   #2
Rewards Points: 352
Re: Change switched receptacle to constant
Is one half of the device hot already? I cannot see the tab for the line side.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old 04-15-2019, 10:31 AM   #3
Rewards Points: 18
No, the bridge wasnít broken. The whole plug was switched.
Change switched receptacle to constant-f32a338f-d5c1-49d0-8e6e-25860047fae0.jpg
Old 04-15-2019, 11:06 AM   #4
Rewards Points: 352
You will have to find the power source. It is most likely up at the switch. This is feeding on thru to another device. So what you do to this device, will happen to the other.
Use an electrical meter to find the source. In the switch box, determine the black wire that is currently feeding the outlet. Splice that to give full time power to the outlet. But all things really depend on where and how power first comes into this circuit. There are a couple variables at that point.
Andrew
Old 04-15-2019, 11:14 AM   #5
retired framer
Rewards Points: 10,532
Andrew
It looks like the power source Is right there marked 2
The two blacks to the outlet might mean there is another switched outlet.
It could be left switched or made constant.
Do not use flat bottom gables with scissor trusses.
Old 04-15-2019, 11:55 AM   #6
Rewards Points: 18
Need a little more help. We havenít found any other switched outlets. Either way, we want them all to have constant power.
Hereís a better photo of one of the switches. I assume the wires in the top right corner are coming from the other 3 sway switch.
what lines am I testing either in the switch box or the receptacle box? I need to use a multimeter as my non-contact tester is buzzing anytime I get near the boxes.
Change switched receptacle to constant-09a577fa-68bc-485d-a3ce-efd454ac9a84.jpeg
Old 04-15-2019, 12:06 PM   #7
retired framer
The red could indicate a 3 way switch or a half switched outlet or two circuits.
The white connected o black might indicate a switch leg or a 3 way switch.
Do you have a meter?
Old 04-15-2019, 12:18 PM   #8
Rewards Points: 18
I have a meter. The receptacle was controlled by 2 3-way switches. I posted pics of the 2 switch boxes and receptacle box in my original post
Old 04-15-2019, 12:31 PM   #9
retired framer
This looks like what you have, and one of the 2 wire cables there would be the power supply.
Old 04-15-2019, 12:43 PM   #10
Rewards Points: 18
Certainly similar. Although my receptacle has 6 wires in the box. 3 sets of 2-wires. Iím still lost.
Old 04-15-2019, 01:12 PM   #11
Rewards Points: 18
Can there be some re-wiring in either of the switch boxes to replicate the action of the switch, so that there is power in the receptacle?
Old 04-15-2019, 01:13 PM   #12
Rewards Points: 352
You need to find the power source. It will be a single 12-2 cable. One black and one white wire. That is the most likely the source power.
This is the reason why electricians do what they do. They know how a simple circuit works. You may want to hire an electrician. Not to bash you on this, but you need to have some knowledge of simple circuits, and how they work. What to look for instantly in a box as to what is what without getting killed. As you see, there is only so much troubleshooting that pictures and text can do.
Andrew
Old 04-15-2019, 01:31 PM   #13
Rewards Points: 18
I hear ya. No worries. Perhaps I know a little more than Iím letting on. The setup though is compounding me.
Hereís a new photo. Iíve determine where the power is coming from. Highlighted in red. As a side note, the three wires circled in hello where originally spliced together.
Any thoughts now how to proceed to make constant power here and the downstream receptacles?
Change switched receptacle to constant-8d1dc946-ceab-4442-b26e-d84b4b08db38.jpeg
Old 04-15-2019, 01:52 PM   #14
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 3,960
Put the receptacle box back together the way it allwas before.
CONFIRM it works as it it did before.
Then go to the SWITCH box(s) to make the adjustments needed.
Replace with blank cover(s) when done.
TarheelTerp is online now   Reply With Quote
Old 04-15-2019, 02:10 PM   #15
Rewards Points: 352
Cool Man, Thanks.
When you are finished, please label the back of the cover plates are to what is now configured and where. This will make note to the next person that has to work on this.
I have never liked a switched outlet. One thing I wish that we could un-invent. I know that is not even a word.
I do not really like configuring everything at the switch. I would rather be able to remove the switch box completely if you want. I would configure everything from that outlet on. You know power is there. Now all you have to do is determine the wire that is feeding the next outlet in line. Take the black and white that you have determine as power. Find a single 12-2 black and white that is feeding the next outlet in line. This is there a tone generator and wand coming in really handy. Or you can create a plug that is tired together and use the ohm meter. Take any old or new part of an extension cord and cut off the male end, leaving about a foot of cord. Tie all the wires together. Plug that into a dead outlet. An outlet with no power. Use your ohm meter to find the wires that are feeding that outlet by touching the black and white from this outlet. Having removed all wires from the device of course. One you have a short, you have found the two wires that are connected together at the other device.
Now you have power, and know the 12-2 wire feeding the other outlet(s), connect the power wire to the outlet, connect the downstream device wire to this same outlet, and you are done. Remove your hand ohm wire tester, and turn the power on to this circuit. Test to ensure there is no power on any wire at the switch. When that is confirmed, the switch can be removed if needed/wanted. And label back of the blank cover stating so. Put the other devices back into the wall boxes.
Andrew
Multiple switched lights into receptacle Zamboknee Electrical 8 03-12-2016 07:49 PM
Switched duplex receptacle miamicuse Electrical 12 12-20-2014 02:12 PM
How to make a full switch recepticle half switched and half constant power? johncdbass Electrical 8 11-15-2010 12:19 PM
changing a switched receptacle to a ceiling fan travisc Electrical 1 06-08-2010 10:53 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
