Change 100 Amp To 200 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2010, 07:49 PM   #1
change 100 amp to 200 amp
i am buying a doublewide home. the house has 100 amp service. i would like to switch to a 200 amp service. what is involved and is it done regularly. how much for the parts and equipment?
logan1881 is offline   Reply With Quote
Old 02-05-2010, 08:21 PM   #2
Possibly a new feed from the pole
POCO has to verify they have capacity to upgrade, usually not a problem
Is this in a park with other homes with similar setups?
Sometimes POCO pays for this (wire) sometimes not
New meter base
New wire from meter to panel
New panel
In some cases local Inspector may want you to upgrade circuits
But not supposed to be required - may depend upon existing setup
Service is upgraded all the time
Prices can vary widely by location & what POCO requires for equipment
Old 02-05-2010, 08:22 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
A service replacement on a mobile is not what I'd call DIY work.
I would call a few electricians and get quotes to do the whole job.
Old 02-05-2010, 08:24 PM   #4
Remember, service equipment CANNOT be mounted on the house. It must be on a pole or pedestal or similar with a four wire feeder to the house.
Old 02-05-2010, 08:24 PM   #5
Electrical Contractor
kbsparky's Avatar
Are you tripping out your main breaker? Planning to add significant loads?
-KB
Old 02-05-2010, 08:49 PM   #6
the main breaker is not tripping but every outlet has a reset button and have to be reset frequently. this would be something to do for resale value down the road and for convieniance. no i would not do this myself. the feed is all under ground. the house is in a cul-de-sac and there are no poles. other houses here have 200 amps. will this project cost me over $2000?
Old 02-05-2010, 09:09 PM   #7
Sounds like GFCI tripping
A new service will not fix that
Prices vary widely by area, get several local quotes
Old 02-05-2010, 09:25 PM   #8
Rewards Points: 1,016
Agreed, spending the money on a 200a service will not fix this. GFCI's can do nuisance tripping and have to be reset. Can be a old/tired GFCI, loose connection on the protected circuit, a device on the circuit, etc.
Discussion on Contractor Estimates/Contracts ARI001 General DIY Discussions 19 11-25-2009 10:47 PM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 09:38 AM
Changing potty. Do I need to change the flange out? tarheelblue Plumbing 9 09-04-2008 11:41 PM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 07:26 AM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 06:41 PM
