Chandelier Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 12:39 PM   #1
Chandelier wiring.
I just bought a new chandelier by illuminating experiences.
ELF 9 Linear Chandelier. It has 6 bulb sockets. It did not come with any instructions.
There are 2 sets of wires. Each has 3 wires coming out all 3 wires were entwined, therefore I thought one set will go to the positive and the other to the negative, the ground wire was already screwed to the housing. However, whenever I tried to connect, the main switch tripped. I tried to change but the same occurred. These wires were neither coded or labelled.
Is there any way to figure it out.
Thanks.
mt8330 is offline   Reply With Quote
Old 02-16-2014, 12:43 PM   #2
With a continuity checker.
The lamp socket shell is supposed to go to neutral (white), the lamp socket center contact is supposed to go to hot (black) and the other is ground.
Old 02-16-2014, 12:55 PM   #3
Rewards Points: 582
show us a picture of the wires.....ben sr
Old 02-16-2014, 01:01 PM   #4
Rewards Points: 3,396
Thanks.
The code reads the neutral has to be identified.................so.
maybe it is or maybe it's not..................
If there's writting on one and not the other, it's the neutral.
If one has a rib in it's insulation, it's a neutral...
If one looks different at all... it's the neutral.... (your probably saying how can I tell different if I'm comparing two.....??? most of the time you can..)
check with a tester (not your tongue) if you want to be sure....
ritelec is offline   Reply With Quote
Old 02-16-2014, 01:28 PM   #5
Thanks Yoyizit, Ben and Ritelec for ur replies but I am still not sure what to do.
here are the pictures of chandelier and wirings. there are two wire, both similar to this one. Each has these three wires with no labels or color coding.
Old 02-16-2014, 03:31 PM   #6
Oh my
Looks like ground neutral hot.
Looks like your going to need a meter.
The Following User Says Thank You to ritelec For This Useful Post:
mt8330 (02-16-2014)
Old 02-16-2014, 09:53 PM   #7
Rewards Points: 808
Thanks.
EACH of those cable contains 1 hot, 1 neutral, and 1 ground. If there was no labeling on the ends of those cables, you have to check with a continuity tester to determine which is which.
IslandGuy is offline   Reply With Quote
Old 02-16-2014, 10:00 PM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It could be that those cables contain two hots and a neutral in case you wanted to be able to have two switches controlling the fixture. The ground could be carried by the support cables. Like what has been said before, you will need to meter continuity between the tab in the socket and each of the wires to find out.
The Following User Says Thank You to k_buz For This Useful Post:
mt8330 (02-16-2014)
Old 02-17-2014, 03:50 AM   #9
dmxtothemax's Avatar
Rewards Points: 7,824
YES !
Your going to need a meter !
There's plenty of cheapies out there !
Come back to us when you have one !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
mt8330 (02-17-2014)
Old 02-17-2014, 08:11 AM   #10
Read a little on the model # and it looks like he may have DC voltage lamps? Maybe missing DC converter/Rectifier
- Chandelier wiring.-image-1965801809.jpg Smaller wires you mention may be the DC voltage? - Joe
Focused2 is offline   Reply With Quote
Old 02-17-2014, 10:01 AM   #11
What's strange is that
the hot, neutral & ground wire in a conventional 120 vac chandelier are not connected to each other and so
no matter which of the six ways you hook up these three wires to the three connections in the ceiling box, no breaker should trip.
Old 02-17-2014, 10:12 AM   #12
Licensed electrician
Rewards Points: 3,766
If the hot is connected to ground at one end and the other end is grounded the breaker will trip.
Chandelier wiring problems Whyjune1st Electrical 25 12-14-2012 08:22 PM
Wiring issues installing chandelier seminole1 Electrical 0 04-03-2011 04:01 PM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 06:22 PM
Ceiling Fan Wiring Problem kayl Electrical 7 02-23-2011 06:19 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
