Ceiling Light Fixture Octagon - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2014, 06:00 PM   #1
Rewards Points: 225
ceiling light fixture octagon
Need to replace an electrical box for a ceiling light fixture. Saw a steel city 4 inch octagon box with v bracket that said for conduit. model 5415112v. Can this be used for the ceiling light fixture? Thanks.
gt1935 is offline   Reply With Quote
Old 04-15-2014, 06:36 PM   #2
Electrical Contractor
kbsparky's Avatar
Your cat # is a bit off. It should be 54151-V-1/2
It looks like this:
It will work with conduit systems, and other wiring methods with the proper connectors. Yes, it's made for ceiling light fixtures. But not for fans.
-KB
Old 04-15-2014, 06:42 PM   #3
Licensed electrician
Rewards Points: 3,848
It can also be used with other wiring methods besides conduit.
Old 04-16-2014, 03:30 PM   #4
Rewards Points: 225
Is 15.5 cu in too small for two 14/2 wires with metal clamps and ceiling fixture with 2 or 3 wires. Does the metal bar for the ceiling fixture add anything? Thanks.
ceiling light fixture gt1935 Electrical 0 12-18-2013 05:59 PM
mounting fixture to light box without ceiling Gary Phillips Electrical 5 07-17-2013 12:14 AM
5000k Light Blulbs for Ceiling Fan Fixture (clean white light for living room) cmf0106 Electrical 10 01-12-2012 10:04 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
Problems Installing a Light Fixture onto a Ceiling Fan adk97 Electrical 4 08-16-2010 05:30 AM
