Ceiling Fans - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 10:22 PM   #1
Ceiling Fans
Just finished installing two ceiling fans. One works great the other not so great. The Fan works fine but when I turn on the light it hesitates about a second or two before it comes on. I have double checked all of the wiring and can't find anything wrong. Could this have anything to do with the wattage limiting device in the light kit? If not, any suggestions?
EP915 is offline   Reply With Quote
Old 02-28-2010, 01:06 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
We had a ceiling fan in our last house that would hesitate about 1 full second from flipping the switch to lighting up, however I was using a CFL bulb. Are you using the same bulb(s) in each of the fans? If so then I'm not sure.
fetzer85 is offline   Reply With Quote
Old 03-01-2010, 12:04 AM   #3
Mad Scientist
If you're using regular incandescent bulbs, not CFL, it's almost definitely the wattage limiter. I just hung a brand new Westinghouse fan a couple months ago, and it has the same slight hesitation. I believe the wattage limiter takes a brief moment to measure the wattage of the installed bulbs.
McSteve is offline   Reply With Quote
Old 03-01-2010, 02:38 PM   #4
I'm using the bulbs that were supplied with the fan. I'll check to see what kind they are but I would hope that the manufacturer would include the correct type.
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Two Ceiling Fans in the same Circuit soup66 Electrical 2 05-20-2008 12:30 AM
Matching Ceiling Fans? fmfd35 Interior Decorating 3 01-25-2008 10:13 PM
Flush Mount Ceiling Fans argana Electrical 6 01-05-2008 05:43 AM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-24-2006 11:23 PM
