Ceiling Fan Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 10:06 PM   #1
ceiling fan wiring
I want to hang my ceiling fan but everyone is talking about a black wire coming from the ceiling but we do not have one only a red, white and ground wire. Do we hook up the blue and black wire to the red wire??
sterling424 is offline   Reply With Quote
Old 06-06-2010, 02:07 AM   #2
Two options here:
1. Provide a little more information, was a ceiling fan up before, or was it just a light fixture. If it was just a light fixture, how was it controlled, by a wall switch. Finally, if it was controlled by a wall switch, did the switch control anything else? Also, how old is the house?
2. Test with a voltmeter, red to white, and red to ground (they should be nearly the same. If you are getting 120V (if in North America) then it should be fine setting up ceiling fan black and blue to the red wire, and white to white.
Troglodyte is offline   Reply With Quote
Old 06-06-2010, 04:37 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by sterling424 View Post
.....only a red, white and ground wire. Do we hook up the blue and black wire to the red wire??
Sterling welcome to the Forum
Yes, the blue & black would connect to your red wire.
The blue wire on a new fan is normally the fan light while the black is the fan motor. The power to the fan will be turned on or off by your present wall switch while the light and fan itself are controlled by the pull chains.
Disclaimer
& Stay Safe
.....Bob Lavery
wiring a ceiling suspended projector amakarevic Home Theater 7 03-26-2010 08:25 AM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
HELP! - Ceiling light wiring bryankerr Electrical 2 10-11-2009 02:08 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
