Ceiling Fan Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2014, 08:29 AM   #16
Licensed electrician
Rewards Points: 3,872
Originally Posted by csab_ View Post
If you have a switch loop then you have a switched hot white wire, which is only hot when the switch is on (should be taped black though).
If so it means the switch loop was wired wrong. The white needs to be the constant hot to the switch.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
clw1963 (08-26-2014), csab_ (08-26-2014)
Old 08-26-2014, 12:33 PM   #17
Rewards Points: 774
Don't forget you need to change out the ceiling box for one that is fan rated or support the fan independent of the box.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
rjniles (08-26-2014)
Tags
ceiling fan , electrical wiring , neutral
Ceiling fan wiring mess mitchell1297 Electrical 2 05-16-2014 05:26 PM
Help with wiring Ceiling fan to dimmer to light fixture. how was it wired? RedDirtdog Electrical 3 04-22-2014 12:05 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
