Ceiling Fan Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 10:48 PM   #1
ceiling fan wall switch
does the electrical code require a wall switch for a ceiling fan with a light? what about a fan without a light?
biknscott is offline   Reply With Quote
Old 12-07-2010, 10:56 PM   #2
As I understand code, certain rooms require either an outlet or a light controlled by a switch at the room entrance. If your ceiling fan is to serve as such a light for such a room, then I suggest that being a fan does not relieve it from the requirement to be switch-controlled.
But, this is just my speculation based on logic. Hopefully, a code guru will confirm or clarify.
oberkc is offline   Reply With Quote
Old 12-08-2010, 06:05 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 58
If you do not have a wall switch, you will soon wear out the pull chain switch in the fan. And after it running on high speed all night while you are trying to sleep., you will wish you had a wall switch. Personally I like 2 wall switches, one for the fan and one for the light.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 12-08-2010, 08:16 AM   #4
Rewards Points: 2,070
You can do both with remote add on.
COLDIRON is offline   Reply With Quote
Old 12-08-2010, 08:21 AM   #5
Rewards Points: 256
Remotes are for situations where adding a switch is difficult and people who can't do wiring.
If you use a remote or just the pull-chain, you will wish you installed a switch.
And I also vote for two switches.
If you have bare walls or easy acess run some wires for two switches.
michaelcherr is offline   Reply With Quote
Old 12-08-2010, 09:29 AM   #6
I disagree with you people can have it anyway they want. wall switch, with remote, two wall switches with remote, no wall switch remote, remember remote no pull chains, speed control and dim control built in.
People just have to decide what they want and how bad they want it.
A lot of people would disagree with you as far as the knowledge comment add on remotes still are a challenge for the average home owner. Beside that we aren't talking knowledge here we're talking switches and remotes.
Old 12-08-2010, 09:38 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 58
The advantage to having a wall switch, even with a remote is:
If the remote (or the remote battery and you do not a have a replacement handy) dies, you can still turn off the fan and light.
As far as using only pull chains: I have replaced more that a few for people who broke the chain off in the switch.
Old 12-08-2010, 01:39 PM   #8
Good point
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Where new wall and "popcorn" ceiling meet klein Drywall & Plaster 2 02-04-2010 01:20 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 07:11 PM
