Ceiling Fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 09:47 AM   #1
Ceiling fan switch
I have a Casablanca ceiling fan with a variable speed switch that no longer works. I think it is the rheostat and would like to replace that with a 3-speed switch. Can this be done?
ClaytonW is offline   Reply With Quote
Old 08-14-2010, 09:53 AM   #2
Licensed electrician
Rewards Points: 3,662
Is this a wall switch or the switch mounted near the motor?
Old 08-15-2010, 08:43 PM   #3
It's the switch near the motor. The fan has no light, just the pull chain on 1 side & the rheostat dial on the other. Switch & motor both work fine.
Old 08-15-2010, 08:50 PM   #4
The 3 wires from the unit to the switch box are black, blue & white. on the the rheostat there are 2 wires, black & white. The switch has 3, black, blue & red. Original hook up was black supply to black switch, blue supply to white rheostat & black rheostat to red switch. The white supply & blue switch wires were both capped off & not connected to anything.
Old 08-22-2010, 09:35 PM   #5
Does anyone have any ideas? Can this be done or do I need a new fan?
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-13-2009 11:09 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
