Ceiling Fan Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2018, 08:05 AM   #1
Rewards Points: 2
Ceiling fan problem
after wiring up a ceiling fan, to existing wiring, I seem to have no power to the fan. Switches check out ok and have power. Hooked up a trouble light to the ceiling wiring and when testing the switches for power, I accidentally touched the side of the switch with the tester and the trouble light came on. As soon as I take off the tester, there is no power to the ceiling wire. Any suggestions?
tclick is offline   Reply With Quote
Old 09-16-2018, 09:35 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,022
Re: Ceiling fan problem
You may be dealing with a switch loop. Post a picture of the switch pulled from the box and the wiring in the ceiling box so we can see what you see. Where does the power come in? At the switch or at the ceiling box?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 09-17-2018, 05:30 PM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 4,774
A little confused here.
You connected the trouble light to the ceiling wiring and switches. I take it you mean a voltage tester. You did not indicate if you were getting any voltage at the ceiling wiring.
If it were me, I would troubleshoot in sequence.
Is there power at source side of the switch?
With the switch on, is there voltage on the feed side of the switch?
With the switch on, is there voltage at the wires in the ceiling?
Identifying where there is no voltage will narrow down where the problem could be.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Another Ceiling Fan Wiring Problem YoLlama Electrical 13 12-05-2017 07:07 PM
Ceiling Fan Light Problem donnyruss General DIY Discussions 6 11-14-2014 05:23 PM
Painting ceiling problem: oldberkeley Painting 15 01-29-2014 05:08 PM
Ceiling Paint Problem camaro guy Painting 3 12-04-2011 08:20 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
