Ceiling Fan Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 08:32 PM   #1
ceiling fan problem
I have a Hunter ceiling fan (remote only controls) that you can control the fan with the remote, but you can't turn off the lights so you need to unscrew the light bulbs to turn off the lights.
Any suiggestions on how to fix?
timchi29 is offline   Reply With Quote
Old 06-21-2009, 08:40 PM   #2
dSilanskas's Avatar
You need a fan/light control.
dSilanskas is offline   Reply With Quote
Old 06-21-2009, 08:42 PM   #3
what?
Old 06-21-2009, 08:46 PM   #4
how to fix fan remote control problem
Originally Posted by dSilanskas View Post
[You need a fan/light control.]
Sometimes the simplest answer is the best answer!Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 06-21-2009, 08:46 PM   #5
dSilanskas's Avatar
The remote that you have that controls your fan does it have a light button on it? Or does it just have a fan?
Old 06-21-2009, 08:50 PM   #6
It has a power button, button for ceiling fan speeds and a button for the light. The power and fan contril works, but just the light does not turn off. It worked at one time.
Old 06-21-2009, 09:22 PM   #7
Electrical Contractor
kbsparky's Avatar
Bad remote receiver. Replace it.
Old 06-21-2009, 09:24 PM   #8
I am going to try to change the dip switch settings first. Where are they normally at in the ceiling fan?
Old 06-21-2009, 09:31 PM   #9
kbsparky's Avatar
The DIP switches affect both the fan and light functions. IF the fan works, but the lights don't then the dimmer module in the remote receiver is probably shot. Changing the DIP switches won't fix this.
Old 06-22-2009, 09:48 AM   #10
J. V.'s Avatar
Rewards Points: 358
Did you hook up the blue wire from the light kit to the blue wire on the receiver? That sure sounds like your problem to me. There is a wiring diagram on the receiver. One wire for the light and one wire for the fan. Check the connections in the ceiling box. The dip switch settings have nothing to do with your issue. If the fan comes on with the remote so should the light. If it's connected correctly take it back and get a new one.
J. V. is online now   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
pull down ceiling storage crimsonalucard General DIY Discussions 16 02-27-2011 08:39 PM
Ceiling fan control switch problem mandolynn Electrical 4 05-09-2009 05:09 PM
Ceiling fan with two pull chains (lamps and fan) , a wiring problem chats72 Electrical 3 12-30-2008 05:41 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
