Ceiling Fan Double Check - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2016, 09:59 AM   #1
Rewards Points: 20
Ceiling fan double check
I installed my first ceiling fan about 4 or 5 months ago. It's a Hunter that came with the remote setup. However, I decided to wire it to my dual switches (one for the light kit and one for the fan), rather wiring the receiver.
So, I got the light working and the fan working. However, the breaker trips when I plug a vacuum in the same room. The light can be off and it will trip. When I use a surge protector, I can vacuum, no problem. Though sort of inconvenience, we've been using this work around for a few months now.
Recently, I flipped the switch for the fan, then pulled the cord and sparks shot out of the unit, the fan ran for 1 second, then the breaker tripped. I wouldn't think that having an alarm clock, TV, roku, small lamp, and a ceiling fan would pop a breaker. We immediately turned the fan switch off, then reset the breaker. At this point, we didn't bother messing with the fan.
Based on what I've seen, I'm thinking it is the breaker itself. Any ideas?
mnguy15 is offline   Reply With Quote
Old 04-17-2016, 10:00 AM   #2
Rewards Points: 20
Re: Ceiling fan double check
Old 04-17-2016, 10:04 AM   #3
Rewards Points: 20
Here's my wiring:
Here's my troublesome breaker, second from the bottom "Smokes & Master BD":
Old 04-17-2016, 11:10 AM   #4
J. V.'s Avatar
Rewards Points: 580
Turn off the breaker. Lower the fan canopy and find the loose wire you missed when you hooked it up.
In simple terms. Where the sparks are is where your problem lies.
Tags
ceiling fan , power surge , sparks , wiring
Soundproofing common party wall, sanity check SM05 Building & Construction 8 08-03-2015 01:45 PM
Double Layer Drywall Ceiling Falling Neighbor Lee Drywall & Plaster 13 12-05-2012 03:11 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 08:14 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
