Ceiling Fan Conversions - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2010, 06:30 AM   #1
Can a drop rod mounted ceiling fan be converted to a flush mount ceiling fan without purchasing an entire new fan?
BandC is offline   Reply With Quote
Old 03-19-2010, 06:32 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 974
95% of the time, yes.
You would need all the parts that came in the box to make sure you had what you needed.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 03-19-2010, 07:07 AM   #3
JBFan,
Thank you for your reply. The drop rod ceiling fans I would like to convert to flush mounted ceiling fans are already installed in the house I purchased recently. No boxes or parts were left from any of these ceiling fans. I recently totally replaced one of the ceiling fans, but was hoping to save the expense of brand new fixtures for all the other fans. Do conversion kits exist to switch the remainder drop rod ceiling fans to flush mounted fans?
Old 03-19-2010, 11:00 PM   #4
kits..
Some of the big box home stores carry conversion kit parts. Usually located in the lighting/ceiling fan area.
Otherbill is offline   Reply With Quote
Old 03-20-2010, 06:14 AM   #5
Just call me Andrew
Rewards Points: 1,032
You could also contact the manufacturer. They may be able to sell/give you the parts necessary.
Andrew
secutanudu is offline   Reply With Quote
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
