Cat5/coax - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 05:21 PM   #1
Rewards Points: 93
Cat5/coax
Do you guys use standard blue electrical box for phone/cat5 and coax? I am planning on using the plug that has one of each on them and want to know if I should put them in a plastic electrical box. thanks
bfan781 is offline   Reply With Quote
Old 03-26-2010, 05:27 PM   #2
Licensed electrician
Rewards Points: 3,662
Due to bend radius concern it is better to use the open back low voltage rings. Same size as a box, but more room as you can coil the wire in the stud bay.
Old 03-26-2010, 06:42 PM   #3
The low voltage rings are ~$1 each at HD
I buy the .20 small blue boxes & cut the backs off
Old 03-26-2010, 07:47 PM   #4
Rewards Points: 93
So you have to take into consideration the bends? Dave, you cut the back off of an electrical box and that works ok? with what a chain saw? ha ha. just joking. thanks anything you can tell me would be great!
Old 03-26-2010, 07:59 PM   #5
Table saw, chop saw, mitre saw, hand saw....whatever works
Old 03-27-2010, 10:53 AM   #6
Rewards Points: 506
I've just opened up the self gripping wire opening for pretty much the same effect
forresth is offline   Reply With Quote
