Cat 5 Cable Wall Plate - Electrical - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 09:54 PM   #1
Former Contractor
PTP WX's Avatar
Cat 5 cable wall plate
Hi Electrical gurus,
I ran a 50 foot Cat 5 cable from the router in our office to the XBox in the basement. After running the cable we plugged it into the XBox and it worked great for 3 months.
Then my wife became annoyed with the outlet box and hole in the wall. Two weeks ago I cut the Cat 5 cable and stripped it back then wired it into a wall jack to clean up the wires. Now it doesn't work at all!
Are there 'cheap-o' wall jacks that would fail easily?
Did cutting the cable cause some other issue?
Are there any tricks / tips for getting all those little color coded cables into the tiny little receptors? Could I have broken a receptor when I wired it?
Help, please!!!! There is a good football game on ESPN 3 this weekend!
PTP WX is offline   Reply With Quote
Old 11-03-2010, 10:47 PM   #2
Rewards Points: 330
hope you kept the plug end you cut off.if you have it match the jack to plug end.the jack should be a 8 pin?just like your router.you have wires in wrong place or the jack failed.the jack should have diagram...
oleguy74 is offline   Reply With Quote
Old 11-03-2010, 11:35 PM   #3
Mad Scientist
Generally, you need a punch-down tool to get the wires properly seated in those jacks. Some jacks claim that you can just insert the wires and push the plastic cap on to get them seated, but I don't trust it.
Also, those jacks probably have two sets of color codes on them, 568A and 568B. It doesn't matter which you use, as long as you use the same on both ends. From what I've seen, most people use 568B.
And is your wire solid or stranded? Some jacks are only rated for one or the other.
Try to keep as much of the cable jacket as possible intact, the jacket should run right up to the back of the jack. Also try not to un-twist the pairs any more than necessary.
McSteve is offline   Reply With Quote
Old 11-04-2010, 12:15 AM   #4
I found some stuff on wikipedia with color codes. It might help. http://en.wikipedia.org/wiki/Category_5_cable
I think I've seen female to female wall plates. It might be better to purchase and run a new cable and use a plug and play type wall plate.
Shane1 is offline   Reply With Quote
Old 11-04-2010, 12:28 AM   #5
Former Contractor
PTP WX's Avatar
Thanks gentlemen!
The other end is plugged into the router, it is 568B.
Wires are solid 24 gauge, braided together in pairs.
Punchdown tool is included as a cap/punchdown that clips on to the back.
This cable was an absolute pain to run.
I think I'll try another jack tomorrow, I worked on it tonight.... no success.
Old 11-04-2010, 06:37 AM   #6
Try one of these:
http://www.cablestogo.com/product.as...3551&sku=35201#
then all you do is get a wall cover that holds a keystone jack.
you also may be able to get one of these at a home depot or radio shack
baum is offline   Reply With Quote
Old 11-04-2010, 08:25 AM   #7
Do work
Rewards Points: 81
Originally Posted by PTP WX View Post
Thanks gentlemen!
If the router end is 568B, then make sure the Xbox end is 568B. Sounds to me like you have it wired wrong.
liquidvw is offline   Reply With Quote
Old 11-04-2010, 11:55 AM   #8
Former Contractor
PTP WX's Avatar
XBox claims that their system is 568B.
I spoke to an engineer at work and he said they only use the orange wall jacks RJ45? when running Ethernet cables. I didn't get a chacne to ask why, he had to go re-fix something.
I'm going to try that, the wall jack posted by baum looks exactly like what I have now (probably a better brand than mine though). Thanks!
Old 11-04-2010, 01:11 PM   #9
Do work
Rewards Points: 81
It doesn't really matter. Just as long as its the same at both ends.
That's about they funniest thing I've ever heard. What does the color have to do with anything.
Old 11-04-2010, 01:50 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 972
We use 3 colors here at work.
One for the lan cable, one for the phone system(when not hooked to a computor) and one for just interanal testing
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-04-2010, 05:03 PM   #11
Former Contractor
PTP WX's Avatar
Looking at the wall plates, there is regular phone in white / Cat 5 in orange and RG-6. Probably just to stop the office folks from pluging computers into the phone jacks. ???
He said it kind of matter of fact.
Old 11-04-2010, 09:45 PM   #12
"When we refer to a jack or a patch panel's wiring connection, we refer to either the 568A or 568B wiring scheme, which define the pin-pair assignments for terminating UTP cable. The only difference between 568A and 568B is that pairs 2 and 3 (orange and green) are swapped."
So as long as the same theme is used at both ends, there should be no problem.
568B Wiring
White/Blue 5-Blue/White 4 _White/Orange 1-Orange White 2_White/Green 3- Green/White 6 _White/Brown 7-Brown/White 8
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 04:31 PM
Metal Plate for Stud's Face to Protect Cable Lovegasoline Electrical 17 12-04-2009 06:40 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
