Carbide Hole Saw Best When Running Wire? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 07-11-2019, 06:47 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,230
Re: Carbide hole saw best when running wire?
Originally Posted by Yodaman View Post
I mostly use inexpensive spade or paddle bits here. Mostly because of the high probability of hitting nails. These 2 flute spade bits are easy to sharpen on a bench grinder after you hit a nail.
Also, I normally run smaller holes, unless I know I will be running a boat load of cables thru it. 1/2 to 5/8 range.
Spades are good. Love em. But the ease of the speed bores pulling themselves thru the wood can't be beat. Effortless. The first time I used one, it freaked me out.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 07-11-2019, 07:10 PM   #17
Property Mgt/Maint
Rewards Points: 6,164
I have been eyeballing them on Lowes shelf for awhile now. And I do like easy!
[political signature removed]
Yodaman is online now   Reply With Quote
Old 07-11-2019, 07:25 PM   #18
123pugsy's Avatar
Cheap and easy...ah hem...not that....you'll be amazed.
Old 07-11-2019, 07:37 PM   #19
Rewards Points: 936
Careful on the drill though...that self pulling can get the bit going further than the drill can handle. Ask me how I know...
Anyone have a good drill repair guy? Asking for a friend.
NotYerUncleBob2 is offline   Reply With Quote
Old 07-11-2019, 08:10 PM   #20
Rewards Points: 664
I just use Bosch brand spade bits. Most of my holes are drilled using a Ryobi right-angle drill. Nothing fancy at all! I use 3/4", 7/8", 1", and 1-1/8" bits, depending on the number of cables I need to pull through each hole. I only use hole saws when I need to cut holes in eaves and roofs to install service conduit masts, or larger ones to cut holes in drywall to install recessed lights or cut-in boxes for smoke alarms.
BluegrassGuy is offline   Reply With Quote
Old 07-11-2019, 09:08 PM   #21
Rewards Points: 58
Yes, screw feed bits need high tork and low rpm drills.
Wiredindallas is offline   Reply With Quote
Old 07-11-2019, 09:25 PM   #22
Rewards Points: 58
Carbide bits are designed to cut stone/brick/concrete backer board (hardi board). I do not know if they are even meant for cutting wood. I have often wondered this, too.
