Carbide Hole Saw Best When Running Wire? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree16Likes
Old 07-10-2019, 08:06 PM   #1
Rewards Points: 784
Carbide hole saw best when running wire?
I have a new Milwaukee hole set but drilling holes through studs, joists, especially those that are doubled is frustrating. I have 2 strong 1/2" drills that have guts, one is especially as it's low gear reduction and heavy, you can just hear the strength of the gears turning. When I pull the hole saw out, it's hot.
Can I expect faster drilling with less heat from carbide?
Most of my drilling I use 3/4".
JLawrence08648 is online now   Reply With Quote
Old 07-10-2019, 08:43 PM   #2
Very Stable Genius
CodeMatters's Avatar
Rewards Points: 8,148
Re: Carbide hole saw best when running wire?
I prefer auger bits.
CodeMatters is offline   Reply With Quote
Old 07-10-2019, 09:22 PM   #3
retired framer
Rewards Points: 17,374
Or even speed bits would be better than a hole saw.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 07-10-2019, 09:48 PM   #4
Rewards Points: 3,290
I like the Forstner style bits. The center auger removes the wood and the outside bold saw cuts the whole size. I use a right angle drill to get between stud bays. The auger style work fine as well but you may need shorter bits than what Code matters pictured. There are places where those long bits are needed though.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 07-10-2019, 10:12 PM   #5
Rewards Points: 746
This is the best 3/4" bit I've found.
BOSCH-NKST12
brric likes this.
Let it Snow is offline   Reply With Quote
Old 07-11-2019, 05:55 AM   #6
Master Electrician
Rewards Points: 5,392
If this is what you mean by "hole saw", you will be drilling all day. Name:  IMG_0450.JPG
J. V., Yodaman, Nealtw and 1 others like this.
brric is online now   Reply With Quote
Old 07-11-2019, 06:13 AM   #7
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,766
These are terrific.
I did some speed testing and I was popping holes thru 2x4's in about five to ten seconds each. Yes, I'm an animal when I get going on a project.
https://www.amazon.com/IRWIN-Tools-S...gateway&sr=8-1
Yodaman likes this.
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
JLawrence08648 (07-11-2019)
Old 07-11-2019, 06:29 AM   #8
Master Electrician
Originally Posted by 123pugsy View Post
These are terrific.
Those bits are fine, until you hit a nail.
Old 07-11-2019, 06:40 AM   #9
123pugsy's Avatar
Why, what happens when you hit a nail? I guess I missed every one when I built my house.
Old 07-11-2019, 06:46 AM   #10
Master Electrician
You must be lucky. One nail and the flutes are gone. Just my experience. Your results may vary.
Old 07-11-2019, 06:48 AM   #11
Master Electrician
BOSCH-NKST12
Best I've found as well although I prefer 7/8".
Old 07-11-2019, 04:48 PM   #12
Rewards Points: 784
Today I used a flat spade bit instead of the bike saw. I did 2 studs, worked great, fast. I may order the Bosch NKST-12 but or the Irwin Speedbor. Thank you for those two recommendations.
Nealtw likes this.
Old 07-11-2019, 05:00 PM   #13
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,308
Those Irwin speedbores often come on a great sale at blackfriday....I stock up on them with a couple of extra's they are so inexpensive.
(Guess I do hit some nails now and then.)
123pugsy likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-11-2019, 05:26 PM   #14
123pugsy's Avatar
I guess I was mistaken. I must have hit a whack of stuff. Funny thing is, in a cordless drill, these holes just popped thru at 3 seconds apiece, even in this beat up state.
Carbide hole saw best when running wire?-img_9053.jpg   Carbide hole saw best when running wire?-img_9052.jpg
Yodaman likes this.
Old 07-11-2019, 06:09 PM   #15
Property Mgt/Maint
Rewards Points: 8,210
I mostly use inexpensive spade or paddle bits here. Mostly because of the high probability of hitting nails. These 2 flute spade bits are easy to sharpen on a bench grinder after you hit a nail.
Also, I normally run smaller holes, unless I know I will be running a boat load of cables thru it. 1/2 to 5/8 range.
[political signature removed]
Yodaman is offline   Reply With Quote
