Capping Off Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 01:28 PM   #1
capping off light switch
i capped off a light switch that runs hall lights there are 3 switches in different places that run the same lights i capped 1 switch off and now the light won'y work why? there are 2 red wires and 2 black wires attched to the switch and i capped each on individually.
intimidator1b is offline   Reply With Quote
Old 09-05-2010, 05:04 PM   #2
Electrician 30 yrs +
wire nut the two red wires together and wire nut the two black wires together. see if it works then!
huck is offline   Reply With Quote
Old 09-05-2010, 05:05 PM   #3
Rewards Points: 2,800
All three switches were interconnected in a special way (a 4 way switch setup).
I'm xxxxxxxx Can you describe how the wires are grouped (cables they come from) in the back of the box? Can you describe how they used to be on the old switch with pointing out such features as screws darker colored or lettering/markings on the back of the switch?
I'm quite sure what you need is connect one wire from one cable to one wire of the other cable, then connect the other wire of one cable to the other wire of the other cable.
As a reminder, the box may not be plastered over but rather must have an exposed blank cover put on it after the switch is gone.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 09-06-2010, 12:04 PM   #4
2 black wires
I had the same problem...I have a 2 way (2 seperate switches truns the light on or off) and I wanted to no longer use one of them. I capped the wires individually and the light did not work.
What worked: There were 4 wires, 2 black one red and one had no insulation. I twisted the 2 black wires together then capped it. I left the red one and the no insultaion one capped as well. The light works no probs now.
I guess in your case, you could try the same.
Andrew DIY is offline   Reply With Quote
Amana roll out switch light blinking butter99 HVAC 2 04-02-2010 10:19 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
