Can't Remove Old Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 07:10 AM   #1
Can't remove old light fixture
My townhouse is only about 4 years old. I recently purchased it and I have been doing some various updates to lighting fixtures lately.
I want to install a pendant light above the sink in the kitchen, but the old fixture is in my way. There are no visible screws or anything to remove that would be keeping it on the ceiling. I even tried smacking it with a hammer on the back in case the ceiling plaster was what was keeping it in place. It is so solid, it feels like it is somehow bolted in place.
Here are some pictures:
Does anyone know how to get one of these down?
qwho is offline   Reply With Quote
Old 06-16-2009, 08:23 AM   #2
DIY = Done Right 1st Time
Is that silicone around the base of it? It might just be siliconed in place. Take a utility knife and cut away the silicone.
Also have you tried turning the fixture? Sometimes they twist/lock into place.
BowDown is offline   Reply With Quote
Old 06-16-2009, 09:36 AM   #3
I'll give that a try when I get home, thanks.
Old 06-16-2009, 09:52 AM   #4
Could be just years of paint
Usually just the middle screw holds it in place
Old 06-16-2009, 12:51 PM   #5
liscenced electrician
Rewards Points: 540
Does look like silicone from the pic. If you felt around and there are no screws then it just needs to be cut free
jimmy21 is offline   Reply With Quote
Old 06-16-2009, 02:47 PM   #6
A 1/16" thk 3" abrasive cutting wheel sometimes comes in handy. It goes in the chuck on your elec. drill. with the-adaptor-which-name-I-cannot-remember.
JC Whitney has these.
Old 06-16-2009, 02:49 PM   #7
Originally Posted by Yoyizit View Post
A 1/16" thk 3" abrasive cutting wheel with arbor sometimes comes in handy. You mount it on your elec. drill. JC Whitney has these.
Old 06-16-2009, 06:38 PM   #8
Household Handyman
Rewards Points: 1,412
Do look like silly-cone to me also. Cut that silly-cone with a razor knife, do a little, careful twisting so as not to damage the ceiling and see if it will start to come down. Be careful and Good Luck, David
Old 06-16-2009, 07:00 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by Thurman View Post
Do look like silly-cone to me also.....
Dave's got it pegged.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-16-2009, 07:44 PM   #10
Ya just need a bigger hammer
Old 06-16-2009, 07:57 PM   #11
That textured ceiling is FOUR YEARS OLD?
The bracket that should be holding it in place is missing (center) so it must be the paint, caulk or the 1/4" of texture.
220/221 is offline   Reply With Quote
Old 06-16-2009, 07:58 PM   #12
If you twist it you might minimize the damage to the ceiling finish and still break the caulking loose.
Old 06-16-2009, 08:21 PM   #13
it was caulk guys. The center screw was missing because I took it out. I did exactly what someone suggested and ran a razor all around the edge, and it separated right away. It's amazing how solid it was, even with just caulking.
Thanks everyone. The pendant light didn't look so great, I think I am going to end up getting a replacement glass bulb for it, as the glass piece it came with makes it look like it would look better in a grandmother's house.
Also, the guy who asked "that textured ceiling is four years old?" what do you mean by that? Just curious.
Old 06-16-2009, 08:40 PM   #14
I think he was saying that if the light was installed improperly, that would be pretty surprising since the house is so new. Kind of odd that they would caulk it up though, wonder what the reasoning for that was.
Atroxx is offline   Reply With Quote
Old 06-16-2009, 11:51 PM   #15
Rewards Points: 528
Send a message via AIM to theatretch85
Maybe because this is the light above the kitchen sink, the installer figured with water nearby it might be a good idea to caulk it, or it may not have been flat with the ceiling because of the texture and they just used caulk to visually fill in the gap... who knows. I'd maybe be a little concerned if all the fixtures were caulked in place (like in the bedrooms, etc).
theatretch85 is offline   Reply With Quote
Replacing a light fixture JELLY DONUT Electrical 4 01-20-2015 10:07 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
Help! wall light fixture w/ switch 8christiest Electrical 3 08-28-2007 03:21 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Outside light fixture kobra99 Electrical 5 06-19-2007 07:50 AM
