Can't Get Electricity To Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jbfan
Old 07-21-2016, 12:46 AM   #1
can't get electricity to outlet
Hi all,
I installed a 15a gcfi outlet to a 20a wire. when I turned the breaker back on after installing it the green test light lit up, but I couldn't get electricity through the outlet. I hooked up the ground, black, and white wires to their respected places.
I tested it with a voltage meter where I hooked up the wires (so basically tested the wires) and got 120v.
I hooked them up on the bottom of the outlet, not the top with the yellow tape around it. I'm assuming this isn't the problem?
any advice on what I'm doing wrong?
before I hooked this up the breaker was tripped due to a jammed up fan I believe but it is no longer connected.
the breaker is a 20a, and seems to not quite stick in the panel right.
any advice?
thanks!
jdangle247 is offline   Reply With Quote
Old 07-21-2016, 01:15 AM   #2
Licensed electrician
Rewards Points: 3,672
Re: can't get electricity to outlet
The breaker needs to be compatible with the panel.
Did you reset the gfi?
Old 07-21-2016, 03:34 AM   #3
dmxtothemax's Avatar
Rewards Points: 7,578
can you upload pictures ?
would be much quicker.
How did you determine no electricity was flowing ?
dmxtothemax is offline   Reply With Quote
Old 07-21-2016, 09:49 AM   #4
so to respond to your questions. I plugged in a set of lights that I tested on another outlet, no light. I plugged in a power strip, nothing lit up.
idk if this should've worked or not but I put the volt meter into the outlet holes and couldn't get anything.
as to the breaker, the breaker has always been there, it's probably 20 years old I would guess.
Old 07-21-2016, 12:45 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,052
Some new gfci's come tripped and have to be reset when power is applied.
Also, some have lights to tell if there is power, and others show the gfci tripped.
jhil likes this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Jim Port (07-21-2016)
Outlet has more than 1 breaker linked to it... Mark C Electrical 13 05-28-2013 09:18 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 10:36 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
