Can You Tell These Wires Apart? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By hkstroud
  • 4 Post By jeffmattero76
Old 05-02-2019, 01:47 PM   #1
Rewards Points: 2
Can you tell these wires apart?
Hello everyone,
I bought a new light fixture on which none of the wires are labeled. They don't have a ridge or stripe to distinguish them and they are all the same colour too. How can I tell the hot, neutral, and ground wires apart? I'm in Canada by the way.
Thank you for your help.
bdr13 is offline   Reply With Quote
Old 05-02-2019, 02:31 PM   #2
CodeMatters's Avatar
Rewards Points: 6,166
Re: Can you tell these wires apart?
You'll need to use an ohmmeter or continuity tester and check which
wire is connected to the 3 points in the light.
CodeMatters is online now   Reply With Quote
Old 05-02-2019, 03:04 PM   #3
JUSTA MEMBER
Rewards Points: 2,454
As stated you need to trace them, simplest is a continuity tester.
I knew that you were in Canada, you spell Color wrong.
Welcome: Adding your location to your profile page will be a help to others, and you won't need to include it again, because it will be displayed to the left of all your posts.
ED
de-nagorg is offline   Reply With Quote
Old 05-02-2019, 04:48 PM   #4
Rewards Points: 2
looks to me like the wire on the right has a green stripe on it
natektzr is offline   Reply With Quote
Old 05-02-2019, 10:01 PM   #5
hkstroud's Avatar
Rewards Points: 5,550
I agree, one wire appears to have a green strip.
One of the other two wires one should have a ridge or rib. With lamp cord wire the ribbed wire is the neutral, and the smooth wire is the hot.
de-nagorg likes this.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 05-02-2019, 10:18 PM   #6
Rewards Points: 570
I knew that you were in Canada, you spell Colour right.
ED
FIFY
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
de-nagorg (05-02-2019)
Old 05-03-2019, 07:47 AM   #7
Rewards Points: 18
Following up on what CodeMatters said earlier.
Get a cheap multimeter (less than $10 at Harbor freight. Select continuity (will usually sound a tone when there is continuity). Touch one probe to the end of one of the wires, and touch the other probe to one of the following:
1 - the center tab at the bottom of the light socket. When you show continuity, that is your hot wire.
2 - the female threads of the light socket. When you show continuity, that is your neutral wire.
3 - the unpainted metal of the fixture. When you show continuity, that will be your ground wire.
Sent from my SM-G530T using Tapatalk
jeffmattero76 is online now   Reply With Quote
16 AWG primary (copper) wire to extend 16AWG (aluminum) wires from fan to 12v outlet? manwiththedogs General DIY Discussions 3 08-23-2017 09:31 AM
Raise attic floor over wires with 2x2s? gunner666 Carpentry 11 02-04-2016 11:50 PM
Can you use wire nuts on a fan light switch with silvery looking wires? amodoko Electrical 4 10-28-2012 08:26 PM
Are Dead wires allowed or unsafe? Scooby333 Electrical 31 10-01-2012 01:26 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
