Can You Help ID These Wires? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 02:57 PM   #16
22AWG Type CM
it has 22AWG type CM written on the wires. This is not CAT5, since those are already running on blue wires and connected to data-in.
i think these may be security wires. Wonder where the ends go. ANy guesses?
shuss is offline   Reply With Quote
Old 11-25-2010, 06:17 PM   #17
Mad Scientist
That might be a safe bet. If it is alarm wiring, and you can't follow the wire through an attic or basement, it could be hard to find the other ends. If sensors were installed, you might be able to see them embedded in door and window jambs. If no sensors were installed, the ends could well have been left coiled up inside the walls above or below the doors and windows.
McSteve is offline   Reply With Quote
Old 11-25-2010, 09:29 PM   #18
I own a tone signal generator and tracer that is used for tracing wire.
You can buy these at building centers and other suppliers, such as electrical material outlets.
The generator has leads with alligator clips that you connect to one end of a cable.
The tracer is about the size and shape of a banana and has a probe at one end and a speaker at the other end.
With the tone generator turned on, the signal can be picked up from the cable, anywhere along its route.
The end of the cable is where the tone stops.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Ceiling Fan installation, 3 sets of wires in ceiling southnam Electrical 3 09-13-2010 03:00 PM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 07:11 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
