Can You Combine Circuits On A Honda EU7000is Generator For Higher Amperage? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2015, 12:18 AM   #1
Rewards Points: 4
Question
Can you combine circuits on a Honda EU7000is generator for higher amperage?
On a Honda EU7000Is generator. Can you combine the L14-30 on the (120/240 side) and....one of the L5-30 or 20amp (120 only side)....to increase amperage to 50amps?
Can you combine circuits on a Honda EU7000is generator for higher amperage?-img_20150531_200034.jpg
Brianflores is offline   Reply With Quote
Old 06-01-2015, 01:17 AM   #2
Rewards Points: 4
What I was thinking.
Can you combine circuits on a Honda EU7000is generator for higher amperage?-homemade-cheater-box.jpg
Old 06-01-2015, 02:39 AM   #3
Rewards Points: 127
The generator is 30 AMPs max. The outlets are for convenience only. You can not draw the max on each outlet.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
jbfan (06-01-2015)
Old 06-01-2015, 10:36 AM   #4
Idiot Emeritus
Rewards Points: 80
This could be done, but it would involve reconnection of the stator leads.
I wouldn't recommend it unless the person doing it is very familiar with generators.
micromind is offline   Reply With Quote
Old 06-01-2015, 11:04 AM   #5
Rewards Points: 204
I believe what you need is a "Parallel kit" for eu7000.
They say it exists on this page: http://www.mayberrys.com/Honda/generators/eu7000.aspx
Call them:
http://www.mayberrys.com/ContactUs.aspx
Nutmegger is offline   Reply With Quote
Old 06-01-2015, 11:20 AM   #6
Rewards Points: 119
Call them:
The parallel kit is used to hook up two eu7000 generators.
KStatefan is offline   Reply With Quote
Old 06-01-2015, 11:25 AM   #7
Rewards Points: 1,832
What is the KW on the genset?
Jump-start is offline   Reply With Quote
Old 06-01-2015, 12:02 PM   #8
Rewards Points: 2,350
The short answer is "no". The slightly longer answer is that it is possible, but anyone who knows how to do it right wouldn't ask about it here to begin with. So... no.
Old 06-01-2015, 12:16 PM   #9
Rewards Points: 204
Sorry!
Read the title only, and completely misread the question.. DUH!
I thought the OP was looking to parallel two generators..
Now that I read the question -- of course the answer is "NO"
Old 06-01-2015, 04:08 PM   #10
Rewards Points: 3,396
Spring in New Zealand maybe?
Can you combine circuits on a Honda EU7000is generator for higher amperage?-gen.jpg
ritelec is offline   Reply With Quote
Old 06-01-2015, 05:52 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 3,670
This is an inverter generator, so it does not have the potential for reconfiguration that a typical one does.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
micromind (06-01-2015)
Old 06-01-2015, 06:58 PM   #12
Idiot Emeritus
Rewards Points: 80
I missed that; if it is indeed an inverter type, then most likely it cannot be reconnected for 120 volt only.
Can I run several circuits through the same conduit? JeepNick Electrical 19 02-16-2012 03:47 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
