Can Someone Help Me Understand This Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Nealtw
  • 2 Post By lenaitch
  • 1 Post By RAL238
Old 11-10-2019, 08:32 PM   #1
Rewards Points: 2
Can someone help me understand this wiring?
I was replacing a light fixture in my garage today and found some wiring that didn't make sense in the box. Hopefully someone here can help me understand what is going on in there. There are 2 cables of aluminum 12/2 going into the box and 2 cables of copper 14/2 coming out. I've attached a diagram for clarification, but my two main questions are:
How can I be sure that the white wire is a neutral, and if it is should it be connected to the black 'hot' wires like it is?
Also wouldn't it make more sense for the cable feeding the outlet to simply pass through the box rather than be spliced into the lighting circuit?
Thanks for any help
Geverett is offline   Reply With Quote
Old 11-10-2019, 09:16 PM   #2
retired framer
Rewards Points: 15,700
Re: Can someone help me understand this wiring?
The white wire connected to the black should be marked with black like a wrap of tape. it goes to the switch and the power comes back from the switch on the black wire to the light. The light neutral is wired directly to the other neutrals.
Aluminum and copper should have special connectors.
lenaitch likes this.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 11-10-2019, 09:29 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
Neutral is always white but white is not always neutral.
afjes2015 and Nealtw like this.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 11-10-2019, 09:35 PM   #4
Rewards Points: 2,120
With a mix of copper an aluminum wiring, you need to keep the two metals separate from each other. Never twist them together in a wire nut.
The proper connector to use is the Alumiconn connector. Since you have one place where there are 4 wires connected together, connect the 2 copper wires together with a third copper pigtail wire, using a conventional wire nut. Then connect the pigtail and the 2 aluminum wires using a 3-port Alumiconn connector.
Avoid using the Ideal purple wire nuts, as they are not recognized as being safe by the Consumer Products Safety Commission.
Nealtw likes this.
RAL238 is offline   Reply With Quote
