Can Modern Circuit Breakers Handle Knob And Tube? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2010, 09:38 PM   #16
Originally Posted by David911 View Post
If you're measuring 16 volts AC, you might be looking at doorbell wiring. Put your meter on it while someone pushes the doorbell button and see if the voltage drops to or near 0 volts.
There are no doorbells on this house.
Tonglebeak is offline   Reply With Quote
Old 02-25-2010, 09:49 PM   #17
I suggested that because 16 volts AC is a very common doorbell transformer operating voltage. Is it possible that your house used to have a doorbell? I still suspect that due to the nature of the splice coming out of the 2x4. It just looks like a doorbell may have been mounted there at one time.
David911 is offline   Reply With Quote
Old 02-25-2010, 10:25 PM   #18
If I came off rude, I do apologize
As far as I know, this interior wall was added on after the house was built. The reason is because there's 2 layers of hardwood on the floor: the original pine t&g, and then a second layer that looks newer. This wall was built on top of the newer (still old though) hardwood. I can't think of a reason to put a doorbell on an interior wall. Plus, the ceiling joists above are a true 2x6. I don't see why this wall could've housed a doorbell.
With that said though, one of the wires seems to be heading towards the front exterior wall...I may look into this further in a few minutes.
Old 02-25-2010, 10:52 PM   #19
Bleh, it runs through more joists, and I don't have the drywall tore down yet (still got another couple hundred pounds to clean up).
I did just have a "duh" moment. I'm a cable tech, and duh, we have toners. The toners we have can do cable, phone, and I'm positive there are clips to do power as well (I've just never used them before). Perhaps I'll bring the toner home sometime this weekend and trace the wire.
Old 02-26-2010, 09:32 AM   #20
Super Moderator
joed's Avatar
Rewards Points: 23,988
Make sure the power is OFF. Those data cable toners will work but you must be sure the power is off. I have used them in the past to find a buried junction box with an open connection.
One point on forum picture posting. Post pictures that are 720 wide max. Your large 1200x1600 image is making the posts need to be scrolled sideways to read them.
Old 03-02-2010, 04:49 PM   #21
Well, both wires seem to be going to a dead end (somewhere in the center of the ceiling. Perhaps there used to be a light there). With that said, it looks like one of the wires is spliced to another, but that very well may be a neutral.
So, with all of that said, is it possible I'm just reading neutral voltage? This time it was very sporadic before settling down to 20v AC.
Old 03-02-2010, 06:25 PM   #22
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
LOL wow that is bad. Not only is it not in a junction box, but it was hidden.
Old 03-03-2010, 12:25 PM   #23
Which is why I was pissed
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 09:34 AM
Adding a switch to Knob & Tube john burwell Electrical 6 04-07-2009 09:30 PM
knob and tube question marin001 Electrical 7 12-21-2008 03:49 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
