Can Light Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 05:40 PM   #1
Rewards Points: 150
Can light installation
Hi guys,
I want to install some can lights in my basement (nailed to the bottom of the floor joists) and I plan to install 12" ceiling tiles that are stapled to 1 x 3 furring strips. Are the can lights usually set up to accomodate the larger ceiling thickness? If the lights are mounted to the bottom of the joists and then you have 3/4" thick furring strips in addition to the thickness of the tiles themselves you're looking at about 1 1/4" difference from the bottom of the joists to the finished surface. Can I use can lighting and these tiles for my basement?
Steelhead is offline   Reply With Quote
Old 04-19-2010, 05:48 PM   #2
Usually the cans are setup to have 1/2" or 5/8" drywall installed over them. I'm not sure if you can find high hats with adjustable depth or not. Maybe you can install the high hats to the sides of the furring strips instead of the joists? It might take some bending and screwing of the brackets, but it should work.
Shrute is offline   Reply With Quote
Old 04-19-2010, 06:17 PM   #3
Electrician 30 yrs +
Originally Posted by Steelhead View Post
Hi guys,
Most can lights are adjustable. The housing have set screw in the sides of the can for adjustment up or down.Good idea to nail them to the furring strips you might need the clearance too.
Huck
huck is offline   Reply With Quote
Old 04-19-2010, 06:28 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Take your new can fixtures, loosen the height adjustment screws to see how much is the adjustment range.
If the range is not enough to accommodate your furring strips then mount the new cans to short furring strip spacers.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-19-2010, 08:39 PM   #5
Rewards Points: 150
Thanks guys for all the help!
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Extend a circuit/draw power from light Ontario Electrical 3 03-23-2010 06:41 PM
Did I screw up? .....Under cabinet light installation. Don't want a fire hazard! jws3 Electrical 21 08-31-2009 02:14 AM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 03:52 PM
